Old 10-28-2018, 11:52 AM   #41
JSeery
JSeery's Avatar
Default Re: Do ALL banjo rearends require a hub puller to remove the brake drum?
Originally Posted by chopnchaneled View Post
...what is involved in doing this?
"Having the brake drum removed with out pulling the hub on the rear"?
TKS
If I am understanding your question, you can't. The posts are referring to drums that have been modified to come off of the hubs or aftermarket setups. You will not be able to pull the original drums without pulling the hubs, they are an assembly.
Old 10-28-2018, 04:04 PM   #42
mfagan
mfagan's Avatar
Anybody ever use a “knocker”?
Marvin Fagan
214-697-8430
mfagan is offline   Reply With Quote
Old 10-28-2018, 04:22 PM   #43
G.M.
The long taper is made to lock on and could run even WITHOUT a key.
You should clean the hub and axle with lacquer thinner or starting
fluid so it is completely dry and wedges on. If the key has a line down
the side that means the axle has moved. I would replace a worn key
and dry as described above. It takes a good strong puller like the
snap on blue point to remove the drums. G.M.
www.fordcollector.com
Old 10-28-2018, 06:45 PM   #44
my4dv8
Luckily I suppose , we had not driven our new to us 32 very far ,25 or 30 miles. While doing other work , we decided the welded on spring hangers on the original rear needed to go. They were an accident waiting to happen.
First clue was no cotter pins through the axle nuts. Got my trusty puller out . Undid the nuts easily , then the drum and hub just pulled off by hand, the taper was also slathered in grease.
Swapping the rear axle for a 35/36 rear now.
my4dv8 is offline   Reply With Quote
Old 10-28-2018, 11:48 PM   #45
ford38v8
ford38v8's Avatar
G.M.
Now, George, you know the drums are liable to go egg shape or the lugs can be ruined by using that hub puller. I'm sure you know better than that, you must be thinking of that Brand X you got hidden in the garage!
Alan
Old 02-04-2019, 08:55 AM   #46
chopnchaneled
Originally Posted by JM 35 Sedan View Post
If you go with separate hub & drum assemblies, it does make servicing the brakes a lot easier, however, if/when you need to take the complete rear apart, you will still need a puller to remove the hub from the tapered axle, unless the axle nut has not been torqued to spec.
What drum or drums can you use for the rear ?
Thanks
chopnchaneled is offline   Reply With Quote
Old 02-04-2019, 11:38 AM   #47
philipswanson
Switch over to Lincoln brakes on the rear, then the drums come off easy. See Speedway catalog. Much better brake.
philipswanson is offline   Reply With Quote
Old 02-04-2019, 11:59 AM   #48
19Fordy
19Fordy's Avatar
You can use the MT Brake Products 1939 Lincoln drums with your stock hubs if you carefully separate your stock drums from their hubs. They are swedged on. Do not try to separate the drum from the studs with a hammer. You could also use the MT hubs that come with studs pressed in but, reuse your old Ford made wheel bearings Call MT Brake products to confirm.
Old 02-04-2019, 01:15 PM   #49
mfagan
mfagan's Avatar
Marvin Fagan
214-697-8430
Old 02-04-2019, 04:58 PM   #50
ford38v8
ford38v8's Avatar
That's why junk axles have mushroomed threads.
Alan
Old 02-04-2019, 05:03 PM   #51
deuce_roadster
deuce_roadster's Avatar
My understanding is that those "knocker" nuts are great for breaking parts inside the banjo. ANY rear hub that is properly installed and torqued needs to be removed with a puller that engages the step in the hub behind the taper. The remake or original KR Wilson puller is your best option.
I suppose a loose hub that you could almost pull off with your hands would appear to come loose with a "knocker" but not one that is tight enough on the taper to drive the rear wheel.
deuce_roadster is online now   Reply With Quote
