Old 02-02-2020, 11:50 AM   #1
flathead48
Default Power seat parts
Restoring 56 Mercury and looking for info on power seat motor drives, I am missing parts that drive the forward & reverse screw. Thanks
Rick
flathead48 is offline   Reply With Quote
Old 02-02-2020, 02:33 PM   #2
Merc Cruzer
Merc Cruzer's Avatar
Default Re: Power seat parts
Sounds like you are just missing the motor. Looks like Mac's has them for Thunderbirds. I would think they might be interchangeable.
Merc Cruzer is offline   Reply With Quote
Old 02-03-2020, 10:17 AM   #3
KULTULZ
KULTULZ's Avatar
Post Re: Power seat parts
Maybe these Ill's will help -
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 02-03-2020, 02:48 PM   #4
grumppyoldman
grumppyoldman's Avatar
i think I have everything for my power seats on my 55, they have never been hooked up since the restoration was done. I guess they are 6 volt motors, what would it take to make them work on 12 volts?
grumppyoldman is offline   Reply With Quote
Old 02-03-2020, 03:10 PM   #5
Dobie Gillis
Dobie Gillis's Avatar
A solid state 12 to 6 volt reducer would probably be best. The wire wound ceramic reducers won't heat up enough to reduce the voltage by much in the short time you'd be using the seat motor. That said they'd prolly work just fine on 12v. The seat will just move 2X as fast as normal. My Merc has 6 volt factory power windows and they work well on 12V. Just keep appendages out of the way when closing them. They are the same motor as your seat motor.
Often wrong but never in doubt.
Dobie Gillis is offline   Reply With Quote
Old 02-03-2020, 06:29 PM   #6
dmsfrr
dmsfrr's Avatar
Do you have a good wiring diagram for hooking them up? They only need to be connected correctly, and will work just fine on 12v unless you abuse them.
https://www.ctci.org/battery-for-6v-to-12v-conversion/
Old 02-03-2020, 11:03 PM   #7
grumppyoldman
Thanks for the replies, no I don't have a wiring diagram. If someone has it I would like to have a copy. Al
Old 02-04-2020, 07:59 AM   #8
flathead48
Thanks guys for the responses but what I need is the gear that connects the motor shaft to the screw arm that hooks to the seat goes inside 60418.
Old 02-04-2020, 09:47 AM   #9
54vicky
54vicky's Avatar
60481?
54vicky is offline   Reply With Quote
Old 02-04-2020, 10:01 AM   #10
Merc Cruzer
This might be the same or similar gear he is looking for. The transmissions appear to be similar in design. These pictures are of the motor and screwjacks used in m y 53' Merc.
Old 02-04-2020, 12:24 PM   #11
KULTULZ
KULTULZ's Avatar
Thumbs up Re: Power seat parts
Originally Posted by 54vicky View Post
60481?
60481 Is The Drive Assy. The actual gear is (was) available separately.
- WHY IS IT ... -
Old 02-04-2020, 03:27 PM   #12
flathead48
Thanks again guys, the gear is what I need, any ideas where one could buy one ?
Old 02-04-2020, 04:23 PM   #13
Merc Cruzer
If you know the part number you can try Green Sales.
Old 02-04-2020, 04:24 PM   #14
KULTULZ
KULTULZ's Avatar
The PN is BN 7060471-A.
I did not see any on a search but the PN may have been superseded.
Make sure the diagram(s) matches your power seat type.
- WHY IS IT ... -
Old 02-04-2020, 04:59 PM   #15
Dobie Gillis
These goobers show one:
https://www.lincolnoldparts.com/6000...1bb3735097c922
$50, OUCH!
Old 02-04-2020, 05:40 PM   #16
Merc Cruzer
You might be able to buy a whole unit for parts, with a burnt out motor, for less than $50. Just a thought.
Old 02-04-2020, 06:26 PM   #17
Merc Cruzer
Is that the same gear part number for the 1953 Power seat? Any way to check other years and applications for that part number?
You know for 50 bucks, that might be able to be made on a 3D printer, if by chance you have the original gear. Just a thought.
Same price but made out of Brass:
https://www.ebay.com/itm/Seat-Motor-...cAAOSwi49bIE7M
If you have the original gear and know someone in tool and die, it might be another option.
Old 02-04-2020, 09:39 PM   #18
flathead48
Used unit would be great, thanks for all the input.
Old 02-05-2020, 04:12 AM   #19
KULTULZ
KULTULZ's Avatar
Originally Posted by Merc Cruzer View Post
The gear shown is a different PN -
Seat Motor Brass Gear 1952-57 Lincoln 1952-55 Mercury 1952-57 Ford BH-7360471-A
- WHY IS IT ... -
Old 02-05-2020, 04:18 AM   #20
KULTULZ
KULTULZ's Avatar
The problem is with text this old is you would need a period OSI (Obsolete-Supersede-Interchange) Catalog to see where the original PN may have been updated. Different publication dates of cataloging may show an updated PN with no explanation of an update.
- WHY IS IT ... -
