06-23-2017, 08:40 PM | #1 |
Type manual floor shifter to use on Ford F-100
[B]Anyway to get rid of 3 speed shifter on column and put on floor shifter-- 3 speed--who's product and pictures of any done-- have a 55 Ford F-100[/B]
06-24-2017, 09:27 AM | #2 |
Re: Type manual floor shifter to use on Ford F-100
Hurst shifters would probably be your best bet. Why do you want to get rid of the column shift?
06-24-2017, 02:55 PM | #3 |
Hurst did not make an install kit for 53-56 F100. The side cover has 2 threaded bosses for the clutch pivot that interfere with the floor shift levers. (Which point up instead of down) The 57-62 F100 used a hydraulic clutch and car style side cover without those bosses. Hurst made a kit for these years. I have tried this myself on a 54 transmission (on a workbench) without success.
Not sure how easy it is to convert to hydraulic clutch on 53-56. Mike. |
06-24-2017, 04:12 PM | #4 |
Hey 38 conv. I sent you a pm asking about the tank you had advertised a while back. Do you still have? Thanks Greg
06-24-2017, 06:41 PM | #5 |
Question answered thanks for all the help--
I will see what it takes to put a C-4 in--- |
06-25-2017, 09:46 AM | #6 |
06-25-2017, 12:30 PM | #7 |
Thanks for all you help, best way to go is sell 292 engine and install my 351 W engine with Mustang II front suspension kit and I got a NEW rebuilt SBF C-6 with small bell housing bolt up no problem and install my Explorer rear---
