02-19-2020, 09:14 PM | #1 |
Hand throttle notches
My 31 Tudor has never been restored but well maintained. The body + interior parts are all original.
Problem - the notches on the hand throttle are pretty much worn flat. What "make-do" repair can I do to make the control stay in one place while driving. I'd like to use it most when warming up the engine. But, maybe occasionally other times. Is replacement the only possible solution? I really want to disassemble the steering assembly just to the the manual control working/staying in position. All ideas greatly appreciated. Jim G [email protected] - if you want to chat about solutions. |
02-19-2020, 10:06 PM | #2 |
Re: Hand throttle notches
How badly is the rod worn. If it's just the plate. You can deepen the grooves with a three corner file. If the rod is worn as well, most are, then you are going to have to replace the rod and renew the plate.
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
02-19-2020, 10:18 PM | #3 |
Unhook the control rod at the firewall and then rotate the handle up so it goes past the plate it rubs against. Then gently push the handle forward to put just a bit more bend in it so it makes firmer contact against the plate.
Dave / Lincoln Nebraska |
02-20-2020, 12:36 PM | #4 |
The throttle and advance handles are held under spring tension at the lower end of the steering column. If the springs have weakened, the tension can be lost and the handle has no down ward push on the notched plate. I guess one could replace the springs with new ones, or insert some washers cut like a horse shoe to shim the springs for a better tension.
02-20-2020, 12:37 PM | #5 |
Will that work or break something? I have the same problem, but I have been reluctant to try bending the rod in place. Is this a common solution?
02-20-2020, 12:55 PM | #6 |
02-20-2020, 02:44 PM | #7 |
IF you look at the back side of the rods where it touches the "V" notches,..they will be worn flat. That area is supposed to be round. Either weld up the originals and reshape
then replate...OR buy repops and hope they fit.. |
02-20-2020, 05:38 PM | #8 |
get some needle files and recut the grooves. https://www.amazon.com/Hardened-Stre...582238368&s=hi
02-20-2020, 06:04 PM | #9 |
good topic, with no easy solutions. years ago I saw ads for services that would build up the bottom side with weld then replate it, but I have not seen that offered for a long time. I have read about fitment problems with the repros, as one member has said. As I recall the complaint was that the 90 degree bend was not defined enough
getting the lower springs on and off is challenging, as is replacing the anti-rattlers within the tube. too bad the later columns did not use the replaceable quadrant that the earlier versions did. |
02-20-2020, 07:40 PM | #10 | |
02-20-2020, 08:18 PM | #11 |
Keep in mind that they are spring loaded and can be pulled toward you to get some room to work with a file.
02-20-2020, 09:16 PM | #12 |
I had mine all apart. I built up the worn part on the underside of the spark and throttle rods with brass and filed them back to shape. I re-cut the quadrants with 3 corner file and reassembled with new springs.
02-22-2020, 05:13 PM | #13 |
You can weld up the worn away area then carefully grind or file the raised edge to fit into the grooves.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
02-23-2020, 01:02 PM | #14 |
If the rod springs are weak and or the grooves are worn, any issues caused if a second plate is added to the top of the old current plate?
