02-09-2020, 05:41 PM | #1 |
timeing gears
how in the world do you get anything behind the bottom gear to get it pulled off? this is a model B engine
02-09-2020, 05:46 PM | #2 |
Re: timeing gears
A big gear puller. And it takes a lot, comes off hard. Serious heat helps.
02-09-2020, 05:47 PM | #3 |
Re: timeing gears
02-09-2020, 06:13 PM | #4 |
Re: timeing gears
You need the proper tool
02-09-2020, 06:26 PM | #5 |
Re: timeing gears
KR Wilson made a nice tool just for this. Some folks have fabricated their own similar versions of this tool. This link has one on page 7 of the 1936 KRW tool catalog.
http://fordtoolcollector.org/k-r-wilson-1936/ |
02-09-2020, 06:28 PM | #6 |
Re: timeing gears
I see a tag on your tool bob, is it for sale? |
02-09-2020, 08:02 PM | #7 |
Re: timeing gears
Not for sale. I got it on Epay as it said for Model A but it's to
small but if fits my 2N Ford tractor. Bob |
02-10-2020, 11:28 AM | #8 |
Re: timeing gears
02-10-2020, 12:13 PM | #9 |
Re: timeing gears
As Patrick says. I have drilled and tapped that gear on my race engine, just in case.
02-10-2020, 12:31 PM | #10 |
Re: timeing gears
I have an old Proto gear puller set, similar to the picture, I suspect it would work, but never tried it.
02-10-2020, 04:36 PM | #11 |
Re: timeing gears
02-11-2020, 02:30 AM | #12 |
Re: timeing gears
rotorwrench, Thank you for using the fordtoolcollector website
02-11-2020, 12:33 PM | #13 |
Re: timeing gears
Beater, that's an original type of gear, steel, not cast iron, that's a good thing.
02-11-2020, 02:23 PM | #14 |
Re: timeing gears
02-11-2020, 03:19 PM | #15 |
Re: timeing gears
02-11-2020, 07:58 PM | #16 |
Re: timeing gears
well I turned it upside down and got the wire wheel and polished the heck out of them think they will be ok guess we will see. greased them and stated putting things back together. waitin on a HC head now
my lil make do shop is prity old school |
02-12-2020, 02:50 AM | #17 |
Re: timeing gears
As usual, Vince has some good info on timing gears on The Ford Garage. http://www.fordgarage.com/pages/camshaftgears.htm
02-12-2020, 04:50 AM | #18 |
Re: timeing gears
That is a good video. How was the old lower rope seal removed and the new one installed with the crank in place? Can they just be pushed into position? I recall them having some "crush" when I reassembled the motor ~10 years ago.
02-13-2020, 07:17 PM | #19 | |
Re: timeing gears
Also as posted above by someone do NOT put heat on your crank gear unless you want to do you babbit as well. Bad advise from some posting so beware. As was noted the Kr wilson puller for replacing the heat when the crank is in is the best . Also the 6306 installer makes it a piece of cake to install . Experience, the right tool for the job, and being careful is key. If the crank is out you can use a common puller with the crank nut used as your center. Larry shepard |
02-13-2020, 07:20 PM | #20 |
Re: timeing gears
Also , remove you valve cover and clean out the valve chamber and check rod and mains for integrity and clearance including end thrust.
Otherwise you may be wasting time and money ..... Larry |
