Old 12-29-2020, 04:46 PM   #1
Ziggster
Default Mystery holes in Holley 94’s
As you may have noticed based on some of my other threads, I’ve been rebuilding one from the carcasses of three. After cleaning and bead blasting what I thought was the premier one, i noticed a hole behind the choke plate linkage. Luckily, the second best did nit have a hole. Upon closer insoection of the third, I noticed it had a series of holes formed to make a slot. Both holes will provide atmospheric pressure to the accelertir pump well (I believe that is whatcitvus called). I’m guessing having two out of three carbs with these holes is no councidence. So does anyone gave an idea why someone would make these holes?
Ziggster is offline   Reply With Quote
Old 12-29-2020, 04:49 PM   #2
Ziggster
Default Re: Mystery holes in Holley 94’s
Hmmm...Can't upload pics again...
Old 12-29-2020, 05:16 PM   #3
ford38v8
ford38v8's Avatar
If I am understanding your description correctly, the hole(s) you refer to was the second of three versions of float bowl vents. The original location of the vent was an oval vertical slot at the front left side of the air horn. The hole you refer to is at the rear of the accelerator pump, passing through to the float bowl. The third and final location was by means of a tube added at an angle within the air horn itself.
Alan
Old 12-29-2020, 07:17 PM   #4
Ziggster
Finally...
The “second” carb. Hole is behind where choke link was located.
File Type: jpg 3E5220F6-8D5F-48AF-B40B-6C8845086BDF.jpg (46.2 KB, 124 views)
Old 12-29-2020, 07:26 PM   #5
Ziggster
The pic of the third carb will not load...
Old 12-29-2020, 07:28 PM   #6
1952henry
1952henry's Avatar
As Alan mentioned, that is a vent. S'posed to be there.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 12-29-2020, 07:30 PM   #7
Ziggster
Strange. Now works.
The “third” carb with hole.
File Type: jpg A66C8454-4DE1-45CA-9806-E40D7773DFA4.jpg (72.0 KB, 100 views)
Old 12-29-2020, 07:33 PM   #8
1952henry
1952henry's Avatar
Again, credit to Alan. That is an early top with the first version of the vent. I read somewhere that the crank mounted fans wreaked havoc with that vent, therefore the search was on for new location. I think I read it on the interweb, so it must be true.
Old 12-29-2020, 09:30 PM   #9
Ziggster
Interesting as I understand that there are something like 17 or 18 versions of Holley 94. I'm positive the holes in my two carbs are not OEM. Whether they were made after the fact or were part of the origin design, what would be the purpose?
Some closer pics...
Old 12-29-2020, 09:31 PM   #10
Ziggster
Third one...
Old 12-29-2020, 10:09 PM   #11
Charlie ny
Steve,
Hole in photo 2 & 4 IS factory....hole in 1 and 3 I think would be more tucked in
if OEM, looks home drilled.
Charlie ny
Old 12-29-2020, 10:11 PM   #12
1952henry
1952henry's Avatar
Many versions of the body, different model numbers, different size venturis, vacuum port, or not. Differences in tops would be vent location and car vs truck. I have a few tips with those same holes.
Old 12-29-2020, 11:28 PM   #13
ford38v8
ford38v8's Avatar
Those holes are the correct locations of the factory vent holes, but they do look to have been goobered up by some misinformed soul for who knows what reason. They don't look nice, but shouldn't affect the operation of the carbs.
Alan
Old 12-30-2020, 12:17 AM   #14
Newc
Newc's Avatar
Hi; I was told the 91-99 with the original front vent was for the crank fan models only. High mount fans required the internal vent.? Newc
Old 12-30-2020, 12:53 AM   #15
ford38v8
ford38v8's Avatar
While the location of the vent was changed twice as it was thought to be affected by air circulation, the timing of those changes was not related to the location of the fan mount.
To further complicate the question today, when carbs were rebuilt back in the day, there was no effort to match original carb bodies and air horns, resulting in an occasional mismatch showing up on the Concourse.
Alan
Old 12-30-2020, 05:43 AM   #16
Ziggster
Thanks again to everyone. The knowledge out there is just incredible, but more important is that fact that people are willing to share so newbies like me can learn. The "second" carb., the one pictured in posts #4 and 9, does have "Model 59" cast into the bowl section. My "good" carb has no distinguishing marks, but both do have the "94" cast marking, but of course I have mismatched the parts to make a good one. Good to know even concourse quality cars can sometimes muck this aspect up. Lol!
Old 12-30-2020, 05:49 AM   #17
1952henry
1952henry's Avatar
The " no mark" carb was most likely an over the counter replacement.
Old 12-30-2020, 05:05 PM   #18
Ziggster
Just to kinda close the loop, I did find a couple pics of the carbs with the correct vent holes. As @ford38v8 so kindly pointed out in post #13 someone must of "goobreed" them out.
Old 12-30-2020, 05:06 PM   #19
Ziggster
The slotted or oval hole.
