12-21-2018, 07:37 AM | #21 |
Re: Tire sizes again for 16"
30 Closed Cab PU
Thanks for the links Have send emails to some mentioned for pictures |
12-21-2018, 09:30 AM | #22 | |
Glad to help, hopefully you will find what you want/like. As a FYI, not sure if you are aware that if you end up with a tire that is not the same circumference as you originally had, your speedometer will not read correctly. I personally like the 16s I have, many do not like the appearance. They are the same circumference as before, and I did not have to change the "turtle" or have the speedometer rebuilt/customed. |
