07-16-2010, 07:59 PM | #1 |
What is the Correct Splash Apron to Frame hardware?
For my 31, what is the correct bolt/ screw, washer, and nut to attach the running board splash apron to the frame.
I looked in the hardware book and came away scratching my head. It appears you are supposed to use a 1/4" - 28 round head screw and a 1/4" - 20 nut. They also do not list a washer or lock washer. I am guessing there should be a large washer between the screw head and the Apron. I would think there would be a washer and a lock washer on the frame side. Thanks, Kevin |
07-16-2010, 08:08 PM | #2 |
Re: What is the Correct Splash Apron to Frame hardware?
it is a special wide head bolt. Bratton's number 22160 ....$2.00 for four bolts, nuts and washers
07-16-2010, 08:59 PM | #3 |
That was a perfect answer, Pat. Written, with a photo, with a source. Just perfect.
07-16-2010, 10:40 PM | #4 |
The apron to frame bolt was the same as the rear lamp bracket to fender bolt. The large head (in both cases) was changed to a smaller head in late 1930. the bolt was raven finished with the head dipped in black enamel. The nut used was a raven finished hex nut on the apron to frame.
http://www.abarnyard.com/ |
07-17-2010, 12:44 PM | #5 |
Thanks guys!
It turns out the proper bolts were in the package of hardware I got from Roy Nacawitz. Now I just need to get the aprons in a nice shiny black. |
09-11-2010, 04:50 PM | #6 |
Thread Tools | |
Display Modes | |
