Old 09-29-2019, 10:06 AM   #1
johnny
Default Disc trimer /cutter
In the old days an adjustable grinding disc cutter was used to trim down the worn edge of a grinding disc might someone have one surplus to there current needs I would like to buy one .John.
johnny is offline   Reply With Quote
Old 09-29-2019, 12:01 PM   #2
Tony, NY
Default Re: Disc trimer /cutter
Unless you have many to do, I use an old pair (Chinese made) of aviation snips and do it by eye. The uneven edge actually helps for some reason.
Tony, NY is offline   Reply With Quote
Old 09-30-2019, 07:58 AM   #3
51 MERC-CT
51 MERC-CT's Avatar
This one that is available is a little different than the one I used years ago in the body shop.
As stated aviation snips work well considering the $200+ price tag.
https://www.morganmfg.com/ab_cat05.htm
Old 09-30-2019, 09:07 AM   #4
40 Deluxe
Somewhere awhile back I saw a tip in a magazine that said to cut "V" notches in the edge of the disk. Similar to your method.
Old 09-30-2019, 09:18 AM   #5
51 MERC-CT
51 MERC-CT's Avatar
Cutting "V" notches or cutting the disc in the shape of a triangle or square was not meant to provide a 'fresh' area of grinding material but gave flexibility to the disc that allowed it to conform to curved or convex surfaces. (did that back in the 50's)
Old 09-30-2019, 05:21 PM   #6
Pete
Pete's Avatar
If you are careful and practice for awhile, try holding the disc against a COARSE bench grinder wheel.
Cleans the edge up just like new.
Pete is online now   Reply With Quote
Old 09-30-2019, 08:15 PM   #7
34PKUP
34PKUP's Avatar
Don't know what kind of discs you are talking about but the autobody surfacing discs that are being talked about generally have to have about a half inch or more removed to get to fresh material.
34PKUP is offline   Reply With Quote
Old 09-30-2019, 08:19 PM   #8
Pete
Pete's Avatar
Roger on that. It takes a bit of practice to see what angle to hold the grinder but it works slick.
Old 10-01-2019, 12:12 AM   #9
Fortunateson
2x on the bench grinder if it is a hard disc. The more flexible ones will need trimming.
Fortunateson is offline   Reply With Quote
