04-10-2018, 07:59 AM | #1 |
Carb rebuilders
Anyone care to recommend a good person to re-build Zenith carbs.
Thanks in advance. |
04-10-2018, 08:15 AM | #2 |
Re: Carb rebuilders
I have heared Snyders and Renners Corner both do a bang up job.
Mike
04-10-2018, 08:34 AM | #3 |
Re: Carb rebuilders
Berts in Denver also offers rebuilt Zeniths. IIRC, they rebuild them in house.
04-10-2018, 09:57 AM | #4 |
Re: Carb rebuilders
Bert's in Denver does a fabulous job!
There is also Brentwood Bob here on Fordbarn who has started rebuilding Zenith carbs. Very nice man. |
04-10-2018, 10:20 AM | #5 |
Re: Carb rebuilders
You won't find a nicer feller than BRENTWOOD BOB!
Bill W.
04-11-2018, 01:50 PM | #6 |
Re: Carb rebuilders
04-11-2018, 03:58 PM | #7 | |
Re: Carb rebuilders
04-11-2018, 05:39 PM | #8 |
Re: Carb rebuilders
Fun, and there can be mistakes that damage the carb.
I tend to learn from others mistakes. There's a reason for a core charge for a nonrebuildable Core. |
04-11-2018, 07:51 PM | #9 |
Re: Carb rebuilders
I sort of disagree with mfarley & others
Rebuilding a carburetor correctly ain't that easy There are numerous passages that need to get cleaned/boiled out and tolerances and specs met for one to perform adequately Further most available parts (I.e. Repo Belong in the garbage imho) Flow testing and run out adjustments are required I'd go with experience and someone who respects original jets and parts |
04-11-2018, 07:56 PM | #10 |
Re: Carb rebuilders
Here we go! This subject could be debated till the cows come home.
04-11-2018, 08:12 PM | #11 |
Re: Carb rebuilders
OK, lets moo along. LOL
04-12-2018, 08:11 AM | #12 |
Re: Carb rebuilders
I have rebuilt a few and they do not perform properly,I think because of the lousy repro parts.I run a model B carb that I bought 40 years ago,I never opened it and it runs great.I would send your carb out,I believe if you rebuild it yourself it won't be satisfactory.
04-12-2018, 10:00 AM | #13 |
Re: Carb rebuilders
It is really easy to fill cavities in teeth also, but you don't do that yourself, you pay an experienced professional to do that.
It is really easy to sew up a deep gash in your arm, but you don't do that yourself either. Yes, it is easy to rebuild a Zenith carburetor, but you send it to an experienced professional so it gets done properly the first time. Like Bob said, it can be damaged by an inexperienced rebuilder, and the repro parts are less than ideal. An experienced carb rebuilder makes a huge difference. I have rebuilt dozens of Zeniths for club members and friends, it is not easy unless you have access to the proper parts and tools and knowledge. There is no shame in sending it out. After you gather some junkers to play with and a bunch of parts and books and gain the knowledge to do it properly, that's different. |
