04-30-2015, 03:46 PM | #1 |
Speedometer drive gear stripped
My speedometer did not work, the cable is new, and when I spin the cable from the torque tube end with a drill, it registeres speed and counts miles. I took the housing down and found broken teeth and teeth missing. The speedometer cable looks fairly new, and well lubricated.
How does this gear break?
Brian French; 1930 Briggs Town Sedan |
04-30-2015, 03:53 PM | #2 |
Re: Speedometer drive gear stripped
Any chance you tried to but a different gear in the housing than it was designed for? Housings and gears need to match.
Charlie Stephens |
04-30-2015, 04:03 PM | #3 |
Charlie; this is how I bought the car. The housing is marked "19", and it is a mid 30 car with 19" wheels and 3:54 gears, so I am assuming 19 is correct??
04-30-2015, 04:16 PM | #4 |
According to Bratton's catalog 3:54 with 19" tires should
use 18 tooth gear. Bob |
04-30-2015, 04:29 PM | #5 | |
Charlie Stephens |
04-30-2015, 05:28 PM | #6 |
04-30-2015, 07:52 PM | #7 |
I have double checked the rear axle and it is 3:78, not as I previously said 3:54.
The gear in the drive shaft housing looks good. I am just at odds, as to what happened before I purchased the car. The speedometer/ odometer has not worked, since I have owned the car. I was looking at Snyders, and also called Snyders, and they do think I should use the 19 gear. The inconsistency does concern me.
05-01-2015, 07:09 AM | #8 |
Thank you all for the information.
Basically I have to guess that the previous owner had a Catastrophic speedometer cable failure, replaced the cable and gave up. How does the speedometer drive gear shaft retainer, come out? I think I would like to fix my broken gear. Also, steel gear, or nylon gear?
05-01-2015, 09:57 AM | #9 |
Thank you all.
