09-20-2013, 03:38 PM | #1 |
VIN Number Location
Ok,
So here's my first question, hoping someone can help me. Not sure about most states, but when you purchase a car from out of state and bring it here, you have to go to a state licensed inspector and get what is called an OD/ID, which simply means the inspector looks at the VIN or serial # on the title and matches it to the car. I need to have this done so I can tag my car. So, does anyone know where the VIN or serial number is on a 47 Ford SD? |
09-20-2013, 03:48 PM | #2 |
Re: VIN Number Location
It's stamped on top of the left (driver) side frame rail in the vicinity of the front cross-member. They can be hard to find under decades of accumulated dirt, grease, and rust.
See the following link for more information: http://www.vanpeltsales.com/FH_web/f...ialnumbers.htm |
09-20-2013, 04:04 PM | #3 | |
I just went through the ordeal of getting a VIN corrected for my '36. The number was botched years ago (at least three title changes, multiple states, too). I caught it before I bought the car. Took three weeks, and I think we were very, very lucky. Ohio can be tough on bad titles (like taking your car tough). |
09-20-2013, 04:40 PM | #4 |
If the car still has the original transmssion the serial number is also located on the top of the transmission bellhousing right above the inspection plate.
09-20-2013, 04:42 PM | #5 |
Ross I had the exact same problem you had. My '41 Ford had the wrong serial number and was registered as such with the guy I bought it from in Ca. Moved to New Hampshire and title renewed OK because no one looked. Moved to OHIO and they want to actually see the number. I wire brushed the frame area and OMG the number was wrong. Had to take the car to a State Patrol inspection garage 45 Mi. away. They affirmed the number and gave me a correction form.Then the local DMV issued plates. All OK now
09-20-2013, 05:59 PM | #6 |
Some body shop paint guys will do a real good finish sand job with 36 grit sandpaper before painting a frame so it can be practically impossible to find the #. There's a thread on the HAMB about raising the serial # on a rusty frame with chemicals and electrical current but haven't tried it yet. |
09-20-2013, 06:08 PM | #7 |
If interested in this process, you might also check on the subject of law enforcement restoring firearm serial numbers after they've been ground off.
Alan |
09-20-2013, 09:49 PM | #8 |
Thanks to everyone for sharing their advice. I found the VIN # tonight! It is located between the radiator support and first cross member, and the number matches the title, so I won't have any issue with the OD/ID and then I can get it tagged!
Thanks! |
09-21-2013, 03:42 AM | #9 |
Good result!
Welcome to the Barn, lots of helpful people here. Any questions you have, just ask away! Mart. |
09-21-2013, 06:47 AM | #10 |
Always glad to have another Missourian on the Ford Barn. Don't ever be afraid to ask any thing.
