09-20-2013, 12:31 AM | #1 |
Vacuum 221 cu in stock
Men, this has been asked recently without an accurate conclusion can anyone tell me what vacuum is pulled at what RPM on a stock standard 34 221 cu inch motor [that is for example at 1000 rpm equals 19inches] what is the vacuum pulled from the port on the inlet manifold to the vacuum wipers ?? Thanking You.
09-20-2013, 01:10 AM | #2 |
Re: Vacuum 221 cu in stock
I think the reason there was no conclusive answer is because at any given RPM, there are other variables to consider; the throttle opening and load on engine being two. Altitude would be another factor.Try fitting a vacuum gauge into your wiper circuit somewhere in the car and go for a drive, observing said gauge.
09-20-2013, 01:30 AM | #3 |
