05-02-2018, 05:13 PM | #1 |
Everyone's Favorite Game: Name That Noise
I'd like to call on everybody's collective expertise to help diagnose a new noise my A is making.
First, here is a link to a video of the noise, https://www.youtube.com/watch?v=SMkSiOYlupI In the video, I'm coming down a hill. First few seconds, the clutch is in and I have the hand throttle set to about the correct engine speed for 30MPH. Rest of the video, the car is coasting in gear still around 30. This noise doesn't seem to be coming from the engine but it does seem speed related(faster when the car is moving faster). Sitting still and revving the engine doesn't make the noise. The only times I've heard have been coasting down hills and as the revs drop between shifting. Also, seems to be coming from under the floorboard instead of under the hood but it's hard to tell. Thanks guys. |
05-02-2018, 05:37 PM | #2 |
Re: Everyone's Favorite Game: Name That Noise
1 vote for the speedometer cable.....has it been lubed recently?
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
05-02-2018, 05:46 PM | #3 |
I second the spedo cable. Easy to test - just unscrew it from the driveshaft and take it for a ride on those same roads.
No vibrations or anything like that when its happening is it? Just purely speed related?
05-02-2018, 06:02 PM | #4 |
I just replaced the speedometer cable in my '29, had a noise similar.. although more "whine" in it. Disconnected the cable, no noise.. lubed it and re-installed, still had the noise. A few of the strands had frayed where the cable bends at the firewall, and that provided a sound-box effect to amplify the noise, new cable and my problem solved.!
Just a thought.. Good luck.! |
05-02-2018, 08:59 PM | #5 |
One thing I failed to mention, pushing in the clutch and letting the engine idle while rolling on that same hill at 30mph makes the noise go away.
Would have never thought of the speedo cable. I'm ashamed to say but it hasn't been lubed since the car has been in my care....which means it has had no attention in at least 6 years and 8,000 miles. If the weather is nice, I will pull the cable, take the same drive and report back tomorrow. What lube should be used on the cable? |
05-02-2018, 09:25 PM | #6 |
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
05-03-2018, 07:15 AM | #7 |
Graphite makes sense to me. Disconnect both ends of the cable and shoot it in?
05-03-2018, 09:05 AM | #8 | |
Keep track of which end goes into the speedometer, the two ends may be different. Nitrile work gloves recommended!
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 Last edited by 1955cj5; 05-03-2018 at 09:24 AM. |
05-03-2018, 09:53 AM | #9 |
Cable was my 1st guess also
05-03-2018, 02:19 PM | #10 |
Well... not the speedo cable. Disconnected it, same drive, same noise.
Gonna lube the cable regardless. Any other ideas? |
05-03-2018, 02:48 PM | #11 |
I guess it’s time to open up the transmission inspection cover. And take a peek.
31 Tudor 66 Bonneville 57 Chevy pickup 27 T roadster pick up |
05-03-2018, 03:35 PM | #12 | |
I would do as John suggests and take the inspection cover off the clutch housing and see what you find....maybe a loose finger on the pressure plate?
05-03-2018, 04:02 PM | #13 |
Pulled the lower floorboard and went for a little drive. Can't see anything blatantly obvious and still no closer to pinpointing the noise.
What are the odds it's something serious? |
05-03-2018, 04:03 PM | #14 |
Gonna pull the cover now.
05-03-2018, 07:49 PM | #15 |
I think you may be on to something. I rotated the engine around and pushed on all of the pressure plate fingers(the exposed end) with a screwdriver and none budged but one, I was able to push it maybe 1/16". It also looked like the adjusting nut was backed off further than the rest.
What's the correct way to adjust them and can it be done in the car? |
05-03-2018, 08:09 PM | #16 |
Measure the lever height of the others and make the odd one the same, it can be done from the front seat.
05-04-2018, 08:12 AM | #17 |
Good, thats all I was hoping I'd have to do. Thanks! Hopefully I'll have some free time this afternoon.
05-05-2018, 08:38 AM | #18 |
So I tightened up the one nut to match the rest of them, haven't test driven it yet.
New development though. Could it be the timing gear? https://www.youtube.com/watch?v=rldiSdcjPIM That noise has been there for a while but it was always much, much quieter. |
05-24-2018, 10:31 AM | #19 |
Well, it makes noise pretty much all the time now except for when it's under a good load or idling. Always goes away quickly by pushing in the clutch while rolling. Seems to be getting worse but I just don't know how serious it could be.
The rods are in pretty rough shape but were all within clearance spec when I checked last year. Drove it to work and just went out and started it to see if I could get it to make the noise without moving and it sounded perfect. I'm really stumped. It seems to be coming from the bell housing area but it's hard to tell. Last edited by ryanheacox; 05-24-2018 at 10:32 AM. Reason: Add info |
05-24-2018, 11:12 AM | #20 | |
