Old 10-03-2021, 08:32 PM   #1
1930artdeco
1930artdeco's Avatar
Default New KYB front shocks
Ok, the KYB 4515 shock which are correct according them aren’t quite correct as people have said. I wasn’t totally in agreement with cutting open the blade ends of the shock and as a matter of fact KYB said not to do that.
So I emailed them and they suggested a slightly different shock. 4752 fits Toyota trucks and is almost identical in length and stroke. It is about 10mm shorter but has about 15% more damping according to their tech dept. Here is the nice part though, the over all width of the blade is the same but the holes where the bolts go are 10mm wider. So this shock is a direct bolt in without having to modify the shock at all. So tomorrow I will bolt them in and see how they fit. I won’t know how they handle for several months but I wanted to pass this info along if it has not been passed along before.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 10-03-2021, 08:57 PM   #2
KULTULZ
KULTULZ's Avatar
Question Re: New KYB front shocks
What are you cutting?
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 10-03-2021, 10:22 PM   #3
1930artdeco
Default Re: New KYB front shocks
Apparently the way to use the 4515 is to cut open the ends of the blades where the bolts go. It allows you to widen the bolt pattern. I just was a little worried that the shock could come loose. Not sure if it was paranoia or not.
Mike
1957 Country Sedan
Old 10-04-2021, 12:10 PM   #4
KULTULZ
KULTULZ's Avatar
Thumbs up Re: New KYB front shocks
Mike
Well we both know that is treading on disaster. What did KYB say about their original listing not fitting pre-1960, anything?
THANX! for the PN update. It will help many I would think.
- WHY IS IT ... -
Old 10-04-2021, 06:17 PM   #5
1930artdeco
The 4515 is the their correct part number for our application. Here is the tech response:
Hi Mike,
We haven’t had this issue before, but if you have the tools to do so, you would be safe to use a file to widen the mounting holes (along the length of the t-bar) so that they match up better with the bolting points on the vehicle frame. Don’t drill out the holes though so you can use the same bolting points.
KG4752 is very similar to KG4515, but the holes in the mounting bar are about 10mm (3/8”) further apart so it could be a better fit. Only thing is that the damping rate is about 15% higher than KG4515, so you will have a firmer ride as a result.
Regards,
Technical Support
KYB Americas Corporation
[email protected]
1957 Country Sedan
Old 10-04-2021, 07:45 PM   #6
KULTULZ
KULTULZ's Avatar
Take that one to the bank. Not many 57/59 owners use KYB's I guess.
EDIT -
Originating Companion Thread -
https://www.fordbarn.com/forum/showthread.php?t=304170
- WHY IS IT ... -
