Old 09-16-2020, 09:08 PM   #1
30standardcoupe
Default Carburetor display/ Diagram
Greetings,
I have been asked by our Model A club to give a basic demonstration on the functionality of a Model A Carburetor.
I thought about starting off mentioning about fuel flow to the carburetor, then going into basic stuff such as fuel filter inside the carburetor, the proper fitment of the choke/main butterfly, GAV valve, float level, etc.
To "set the stage" I do have access to a Computer, excel, power point, etc.
The average age is about late 50's on up ranging from first time Model A owners, to "Very knowledgeable"
Are there any diagrams or displays out there that show the carburetor functionality etc?
Or is a there a "Cheat sheet" or troubleshooting list or items to look for?
Also, what demonstrations have you seen that really was good or made an impact on you.
I am open to pretty much anything,
Like to hear your ideas,
TIA
Clay
30standardcoupe is offline   Reply With Quote
Old 09-16-2020, 10:16 PM   #2
McMimmcs
McMimmcs's Avatar
Default Re: Carburetor display/ Diagram
Keep it basic because the more complicated you make it the better chance someone in the group will know more than you and play pin-the tale on the donkey. If you’re not already an expert on carburetors why would they ask you to address the subject? .
Old 09-16-2020, 10:43 PM   #3
160B
160B's Avatar
Below is a great web site with lots of information to help you with your seminar.
here are some of the sections
Assembling Carburetors
Back fires at high speeds
Basic Info
Cap Jet
Carburetor Idle RPM and Idle Air Mixture Adjustment
Carburetor Removal and Disassembly
Carburetors and Carbohydrates
Castings
Casting Threads
Choke Arm and GAV Driver
Choke Driver with Wing Nut
Cleaning Carburetor
Cleaning minor dirt, rust particles or sludge out of Carburetor.
Compensator Jet
Compensator Jet Orfice contains dirt or rust, or is too small.
Compensator Jet Orfice is too large.
Complete List of Component Details
Complete List of Procedures
http://model-a.org/
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 09-17-2020, 05:05 AM   #4
Ford Acar
Exactly my thoughts.
Ford Acar is offline   Reply With Quote
Old 09-17-2020, 02:37 PM   #5
AL in NY
AL in NY's Avatar
The attached diagram is the best one I've seen on the Model A Zenith carburetor.
AL in NY
AL in NY is offline   Reply With Quote
Old 09-17-2020, 02:46 PM   #6
AL in NY
AL in NY's Avatar
If the above link doesn't work, here is a photo of the diagram.
AL in NY
Old 09-17-2020, 09:08 PM   #7
30standardcoupe
To answer your question: I fall into the category that this is my first model A. I have worked on allot of forms of Internal combustion engines over the years. I am the type of guy that will dig in and figure the issue out or how to modify it to get it back on the road.
With that being said, I have been dealing with a carb issue/ Model A issue for the past few months off and on. Also reaching out to others for help and advise and listening very attentively to those instructions and keep pressing forward.
I made a check off list, then I am not going back and fourth as much.
Next years president asked me to give a demonstration on carbs, and what I have learned (because I have been dealing with issues) and to basically take it from a newbies point of view.
I am honored to do it, just want to be well prepared,
TIA
Clay
Old 09-17-2020, 09:15 PM   #8
GRutter
GRutter's Avatar
If anyone has a copy of the book "restoring the model a carburetor the Rex Reheis way" it is a bible of information on Model A carburetors.
Rex passed several years ago and I don't believe his book has ever been republished. Don't know what the copyright laws may be but it would be a service to the Model A community if that could be published online digitally.
GRutter is offline   Reply With Quote
Old 09-18-2020, 11:52 AM   #9
Joop
Joop's Avatar
Hope this helps
Joop is offline   Reply With Quote
Old 09-18-2020, 05:25 PM   #10
Gary WA
Gary WA's Avatar
Originally Posted by 30standardcoupe View Post
Greetings,
TIA
Clay
modelabasics.com
www.whidbeymodelaclub.com
