10-19-2015, 06:56 PM | #1 |
Clay Smith cam ID?
Hope that one of you experts can ID this 59AB cam I have
Thanks! |
10-19-2015, 09:04 PM | #2 |
Re: Clay Smith cam ID?
That's a pretty hefty cam. Good for a large cu in engine. No low end torque so definetly not a good street cam.
10-19-2015, 10:18 PM | #3 |
The 272 was a good track cam, but the 282 was more of a top end grind. Should sound great tho.
10-19-2015, 10:56 PM | #4 |
Thanks!
So it has only three digits, rather than four? Any specs? |
10-20-2015, 01:46 AM | #5 |
Yes, it should read 282, its cam lobes have quite a wide flat on the (normally) pointed part of the lobe. Not really a high lift cam, more of a long dwell at full lift cam, quite a high lift rate.
A stout cam, use with high compression heads eg offy 400 (highest off the shelf offy's) 350's would have been good on a small size engine. Martin. |
10-20-2015, 04:08 AM | #6 |
10-20-2015, 04:57 AM | #7 |
High lift and high lift rate are two different things, I agree the Clay Smith cams arnt high lift, but the rate if I recall was correctly was quite high. Sorta gets up quickly, stays full up quite a long period, the closes quickly. I'm sure that's what my notes says? The cam in my notes is actually a 282-2 which had slightly revised exhaust pattern. Again if I recall, my notes arnt with me though.
Martin. |
10-20-2015, 05:56 AM | #8 | |
Yes, I think once Clay Smith took over the grinds from Smith-Jones they tweaked the grinds a bit and added the -2. All of my grinds are Clay Smith's so they read 272-2, 284-2, etc. Curious if anyone is running a 272-2 in there car? It was a popular grind back in the day. Last edited by Tim Ayers; 10-20-2015 at 08:23 AM. |
10-20-2015, 04:11 PM | #9 |
So that's what the -2 bit comes from, thanks for that.
From Ron's book, 272-2 rough idle but ran good on the street. Also states can be used in any weight car. Martin. |
10-20-2015, 05:24 PM | #10 |
If it has a rough idle, that would definetly adversely effect low end torque and so would not be the best for a heavy car. Probably has tight lobe centers and a lot of overlap.
10-20-2015, 06:24 PM | #11 |
Wow! Great factual info. Thanks!
Anybody else care to chime in? |
10-21-2015, 07:55 AM | #12 |
10-21-2015, 11:51 AM | #13 |
Great!
Thank you, Tim. |
10-24-2015, 07:42 PM | #14 |
Tim, any luck?
06-21-2020, 12:43 PM | #15 |
Guys,
I have a Clay Smith cam (M3) for the “60” engine. Anyone have the specs on this M3 cam? Thanks, |
06-21-2020, 09:46 PM | #16 |
I have a piece of a 272 in a drawer someplace with 3 lobs onit. Came fron a Danbury stockcar from the late 50's. Not much was left of the engine as it blew going into turn 3, leading the race.
06-21-2020, 09:58 PM | #17 |
Crud. I never posted the specs. I'll find them and post here later.
Can still get Clay Smith cams ground by George and the gang. |
06-21-2020, 10:13 PM | #18 |
06-21-2020, 11:11 PM | #19 |
Does this cam require radiused lifters?
06-22-2020, 06:04 AM | #20 |
You can still get cam info from Clay Smith Cams check them out on the web.
