Old 09-17-2020, 08:37 AM   #1
cvicky
cvicky's Avatar
Default cluster light socket high beam
my one wire high beam socket is missing
the hole in the back of speedo is about 5/8" but very shallow
any ideas where i can get something ?
cvicky is offline   Reply With Quote
Old 09-17-2020, 04:24 PM   #2
frank long island
frank long island's Avatar
Default Re: cluster light socket high beam
if your auto parts store has a help rack ck that if not ck the internet
frank long island is offline   Reply With Quote
Old 09-19-2020, 05:41 AM   #3
big job
big job's Avatar
Any parts store will have the socket which is more a less standard. Then you need a
#51 6vt bulb now you just have to find the feed wire very odd its not there??
big job is offline   Reply With Quote
Old 09-19-2020, 05:16 PM   #4
dmsfrr
dmsfrr's Avatar
Originally Posted by big job View Post
... now you just have to find the feed wire very odd its not there??
If it helps...
I have wiring diagrams for a '55 and '57 (T-Bird),
on both the power wire to the high beam indicator light is Green with a Black stripe.
Old 09-21-2020, 12:31 PM   #5
big job
big job's Avatar
i'm confused? the wire has to be there, or somebody been in there. Whatever color
wire; comes from the high beam terminal on the foot switch. I think all you can do is
run a wire from foot switch to the high beam on the cluster. Or you open a can of
beans cutting the wire harness. It maybe broken or cut at the harness break out. the
break out means when a wire terminates from the harness...
Old 09-21-2020, 07:24 PM   #6
Daves55Sedan
Daves55Sedan's Avatar
That is a unique and oddball looking light socket too BTW, since it is a deepwell type so the bulb sticks way into the hi-beam well. Kinda looks like a cigarette with a washer around it. Look around under the dash, maybe it is just hanging in there somewhere.
