Old 12-03-2011, 10:13 AM   #1
JerseyJim
JerseyJim's Avatar
Default Tighten Fan Belt?
I am installing a fan belt on a 46 engine. Of course, this engine has separate fan and generator belts. My question? How can you apply tension to the belt and tighten it? I can't see anywhere that you could pry against to stretch and tighten the belt. I am of course aware that when tensioned, there should be an inch of deflection mid-span on the belt. I know there must be a simple answer to this that I'm missing.
Any help would be appreciated.
JerseyJim is offline   Reply With Quote
Old 12-03-2011, 06:33 PM   #2
Vergil
Vergil's Avatar
Default Re: Tighten Fan Belt?
This is what I use.
Vergil
Bigger fonts to aid in reading
Vergil is offline   Reply With Quote
Old 12-03-2011, 06:41 PM   #3
39portlander
39portlander's Avatar
Nice pic's vergil, another tool to make. Hey, I like the paint on that flathead what color is it
39portlander is offline   Reply With Quote
Old 12-03-2011, 06:52 PM   #4
G.M.
Good job on the tool Virgil. G.M.
www.fordcollector.com
Old 12-03-2011, 08:45 PM   #5
Vergil
Vergil's Avatar
It's actually a grey (Krylon engine paint new Ford Grey) but it doesn't look grey here lol., and thanks.
Vergil
Old 12-03-2011, 09:45 PM   #6
oldford2
oldford2's Avatar
Now that is a neat tool to help adjusting the belt. I am going to make one. Thanks
John
oldford2 is offline   Reply With Quote
Old 12-04-2011, 01:07 AM   #7
49r
Nifty looking tool Vergil. I always wondered how they did it in the day. I've levered against a block of wood on my F1 with the other end sitting on the chassis. Another method I've tried is straddling the engine with my backside to the firewall and one foot on each chassis rail while I heave with one hand on the fan and tighten the nut with the other. I'm sure it's not a pretty sight (or sound) ...
49r is offline   Reply With Quote
Old 12-04-2011, 01:31 AM   #8
Mr 42
Mr 42's Avatar
My version
Not so nice but it works.
Mr 42 is offline   Reply With Quote
Old 12-04-2011, 01:42 AM   #9
Old Henry
Old Henry's Avatar
I tighten the generator/pump belt first by inserting my cresent wrench handle under the generator right against the front bracket so the end is on the intake manifold bracket under the front of the generator (see photo) then push down the end of the wrench to "pry" the generator up as tight as I want the belt and hold it there while tightening the bolt that holds it in place. It takes very little effort with that much leverage. No special jig or tool required. Just simple leverage. That belt is the more critical for tightness since it runs both water pumps and the generator. The fan belt I tighten by just pulling up on the fan while tightening one of the bolts that holds it in place. Again, doesn't take much effort to just lift the fan up. It's not heavy like the generator is. Then I can quit pulling up on the fan and tighten the other bolt. I don't think the tightness of that belt is as critical as the other that I get tighter by "prying" the generator up.
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end. *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is offline   Reply With Quote
Old 12-04-2011, 01:54 PM   #10
petemcl
petemcl's Avatar
Smile Re: Tighten Fan Belt?
Vergil
I like that color. Thanks for the tip Vergil!
Pete
petemcl is offline   Reply With Quote
Old 12-04-2011, 04:07 PM   #11
peewee2you
peewee2you's Avatar
Vigil, I like a guy that's always thinking, well done on that concept.
I have an engine hoist and use the boom with a rope around the generator and jack it up to correct play then tight it off.
peewee2you is offline   Reply With Quote
Old 12-04-2011, 06:15 PM   #12
39portlander
This is what makes the FordBarn great. A good thread question and an excellent tool idea out of it!
Because of this thread, we should now have a ford barner Tool of the month! Virgil, you got the month of December wrapped up, no pun intended
Old 12-04-2011, 07:39 PM   #13
JerseyJim
JerseyJim's Avatar
Thanks for the help guys.
I love that tool as well Vergil. I'm sure that Ford Service Departments way back when must have had something like this. I'm definitely going to take a spare wrench and make one as well. Went to a late season car show here in NJ today. Several flatheads in attendance. Got a chance to check out the belt setups on several different engines. My engine is a mix of parts from different years. Still don't completely have this sorted out.
Old 12-04-2011, 09:36 PM   #14
Vergil
Vergil's Avatar
Thanks Jim, My setup (2 av8's) is also a little different. I am running one narrow belt driving water pumps and fan, added another pulley by the fan pulley that drives an alternator. Have 2000+ miles on it so far and have not had any problems with it yet but might shred a belt tomorrow. I like the different belt tightening techniques, they all work and it shows how smart the boys here are.
Vergil
Old 10-11-2013, 08:37 PM   #15
Automotive Stud
Automotive Stud's Avatar
I know this is an old thread, but I figured I would share how I've been doing it for people searching the archives. I've had good luck putting a punch in the slot and prying up. I put a piece of wood on the intake to keep from scratching it up.
Automotive Stud is offline   Reply With Quote
Old 10-11-2013, 09:10 PM   #16
Bassman/NZ
Bassman/NZ's Avatar
Me too.
Bassman/NZ is offline   Reply With Quote
Old 10-11-2013, 10:15 PM   #17
Thaplumbr
Thaplumbr's Avatar
Every time I come to this site I learn something,I've been adjusting mine with a crowbar and a wooden block,I love this place!!!!
Thaplumbr is offline   Reply With Quote
Old 10-12-2013, 05:25 AM   #18
mike42
mike42's Avatar
Thaplumbr......that's what I use. A piece of oak carved out to catch on a bolt head and use my crowbar to pry up the alternator. Vergil that is sweet what you made up !!
Mike
mike42 is offline   Reply With Quote
Old 10-12-2013, 09:25 AM   #19
Ross F-1
Ross F-1's Avatar
Vergil's tool inspired me to make this fulcrum. It works great!
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 10-12-2013, 10:49 AM   #20
Mtn Wudy
Mtn Wudy's Avatar
Ross....Have that chromed,and leave it on the truck...I like it..
I was going to post a photo of my "Bloody Knuckle" that happened the other night when the bar slipped....Walking through the house to get a band aide,she asked me "What did you do this time??".....I'm building one of those today...Carl in SoCal..
Whether you think that you can,or that you can't,you are usually right....H.Ford
Mtn Wudy is offline   Reply With Quote
