Old 05-27-2021, 02:35 AM   #561
V8COOPMAN
V8COOPMAN's Avatar
Default Re: photo1-1-window
Lacy Brake
Click Links Below
T5 W/TORQUE TUBE
V8COOPMAN is online now   Reply With Quote
Old 05-27-2021, 02:59 AM   #562
V8COOPMAN
V8COOPMAN's Avatar
Lacy Chassis
Click Links Below
T5 W/TORQUE TUBE
Old 05-30-2021, 11:56 AM   #563
V8COOPMAN
V8COOPMAN's Avatar
'35-'36
Old 05-30-2021, 05:52 PM   #564
V8COOPMAN
V8COOPMAN's Avatar
32 Pedals
Old 05-31-2021, 06:15 PM   #565
V8COOPMAN
V8COOPMAN's Avatar
34 blower
Old 06-02-2021, 04:49 PM   #566
V8COOPMAN
V8COOPMAN's Avatar
32-34 BANJO...
1935-LATER...
Old 06-05-2021, 05:06 PM   #567
V8COOPMAN
V8COOPMAN's Avatar
Tom Beatty Car
Click Links Below
T5 W/TORQUE TUBE
Old 06-06-2021, 12:42 AM   #568
V8COOPMAN
V8COOPMAN's Avatar
1940 Ford COE
Click Links Below
T5 W/TORQUE TUBE
Old 06-06-2021, 12:44 AM   #569
V8COOPMAN
V8COOPMAN's Avatar
BIG COE TRUCK COUPE
Click Links Below
T5 W/TORQUE TUBE
Old 06-09-2021, 02:03 PM   #570
V8COOPMAN
V8COOPMAN's Avatar
Em manifold
Click Links Below
T5 W/TORQUE TUBE
Old 06-09-2021, 03:00 PM   #571
V8COOPMAN
V8COOPMAN's Avatar
51 merc
Click Links Below
T5 W/TORQUE TUBE
Old 06-10-2021, 11:00 AM   #572
V8COOPMAN
V8COOPMAN's Avatar
T5 Remote Shifter
Click Links Below
T5 W/TORQUE TUBE
Old 06-10-2021, 11:01 AM   #573
V8COOPMAN
V8COOPMAN's Avatar
T5 Y-Block
Click Links Below
T5 W/TORQUE TUBE
Old 06-10-2021, 11:07 AM   #574
V8COOPMAN
V8COOPMAN's Avatar
Ford T5/Y-Block
Click Links Below
T5 W/TORQUE TUBE
Old 06-10-2021, 11:09 AM   #575
V8COOPMAN
V8COOPMAN's Avatar
Different T5s
Click Links Below
T5 W/TORQUE TUBE
Old 06-10-2021, 11:19 AM   #576
V8COOPMAN
V8COOPMAN's Avatar
MUSTANG T5 To Y-Block
MUSTANG T-5 INSTALLATION IN CARS or T-BIRD
Use 1954-62* passenger car stick bellhousing. (3-speed manual)
Will work with 215-223 6 cylinder engines in 52-64 cars
Rancheros are not trucks.
The shifter will be ahead of the front edge of the seat.
Shifter will be approximately 2" to the left of the center of tunnel.
Most S-10 T-5's have a GM bolt pattern and will not fit our adaption methods.
Due to the difference in length of the input shaft you must use a 1993 or older Mustang** T-5.
1994 and newer T-5 transmissions will NOT work! INPUT SHAFT IS TOO LONG
You must change your clutch disc to 1-1/16" 10 spline.
Y-Block cars had 1" 10 spline or 1" 23 spline clutch discs.
Original pressure plate and throwout bearing can be used.
5.0L pressure plate will NOT fit Y-Block flywheel.
T-5 is shorter than original transmissions. (About 3")
Driveshaft must lengthened.
Driveshaft front yoke must be changed.
This adapter places the rear mount level.
*This kit will also work on some Flat-head Ford V8 bellhousings(49-53), Merc Flat-head V8 (52-53), early F-E (58-64) and Small block Ford bellhousings (62-64).
**Some GM T-5 Transmissions have the Ford bolt pattern on the front. Most do not.
Click Links Below
T5 W/TORQUE TUBE
Old 06-12-2021, 05:46 PM   #577
V8COOPMAN
V8COOPMAN's Avatar
American Powertrain T5 Shifter
https://americanpowertrain.com/shop/...-style-offset/
Click Links Below
T5 W/TORQUE TUBE
Old 06-14-2021, 10:07 AM   #578
V8COOPMAN
V8COOPMAN's Avatar
21-STUD "Pilot" Block-CORE PLUGS
Click Links Below
T5 W/TORQUE TUBE
Old 06-15-2021, 03:57 PM   #579
V8COOPMAN
V8COOPMAN's Avatar
59T-6520 LEFT....48-6520 RIGHT
Click Links Below
T5 W/TORQUE TUBE
Old 06-16-2021, 12:57 PM   #580
V8COOPMAN
V8COOPMAN's Avatar
PVC Set-Ups
Click Links Below
T5 W/TORQUE TUBE
