Old 02-10-2020, 09:26 PM   #1
Vanspeed
Vanspeed's Avatar
Default The model a drag link/pitman arm
Questions for the genius brains. Why does a Model A have a pitman arm ball on the opposite side as most drag link setups? Usually the ball is to the outside and the arm is parallel with the ball in the spindle arm. The A has the drag link on an angle, almost parallel to the wishbone. Was that the intent?
Respecting and Resurrecting Ford Model A's.
Vanspeed is offline   Reply With Quote
Old 02-11-2020, 08:14 AM   #2
old31
Default Re: The model a drag link/pitman arm
Huh? You lost me on that one. I guess I do not fall into the genius brain category.
old31 is offline   Reply With Quote
Old 02-11-2020, 09:09 AM   #3
jhowes
I also don't fall into the genius category but I am willing to take a guess If the ball were to the outside would the drag link hit the tire on a sharp left turn? Otherwise it must be a geometry problem that's beyond my pay grade. Jack
jhowes is offline   Reply With Quote
Old 02-11-2020, 09:10 AM   #4
Bob Bidonde
Bob Bidonde's Avatar
To keep the straightest line between the spindle ball and the steering arm.
Bob Bidonde
Old 02-11-2020, 09:13 AM   #5
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
I'm not a genius but my opinion is the reason the Pitman arm ball location is on the inside is to gain more clearance for the L/F tire to clear the drag link on a left-hand turn.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 02-11-2020, 07:08 PM   #6
Vanspeed
Vanspeed's Avatar
Never thought about it hitting the tire. That makes sense.
