12-08-2018, 08:11 PM | #1 |
Drake Needle Bearing U-Joint?
Do I need the big gob of grease like the common Ford type? Thanks: Fred A
12-08-2018, 08:25 PM | #2 |
Re: Drake Needle Bearing U-Joint?
Yes, the same as a regular Ford u-joint. I’ve also heard that corn husker grease works well. I’ve used these the Lincoln style u-joints for many years. They work very well.
Hope this helps. Sent from my iPad using Tapatalk |
12-08-2018, 08:34 PM | #3 |
If your using the repop Lincoln joint be sure to check for end play after you tighten the bolt. It shouldn't have any . The ones I've see were junk. Had better than 1/4" play in and out. Friend of mine ruined two transmissions before we figuired out the problem.
12-08-2018, 10:35 PM | #4 |
So grease as usual. Rechecked the end play and was OK. Didn't seem unreasonable that they could use a more modern U-Joint, but onward and... Thanks Fred A
12-09-2018, 12:18 AM | #5 | |
I've read previous posts here that mentioned needle bearing Lincoln repro U joints weren't the best, but I have no personal experience.
12-09-2018, 02:10 AM | #6 |
Lawrie |
12-09-2018, 08:02 AM | #7 | |
John |
