Old 10-23-2017, 01:46 PM   #1
michael a
michael a's Avatar
Default Antifreeze
I know this must be a subject that has been talked about a million times but I'm unsure so I thought I would ask. I put a new radiator in my car will straight water and now that it's getting closer to Winter I need to get a protected. I have heard about distilled water and regular antifreeze or the 50/50 mix what do you all prefer
Sent from my SM-J700T using Tapatalk
michael a is offline   Reply With Quote
Old 10-23-2017, 01:52 PM   #2
ModelAMike1930
ModelAMike1930's Avatar
Default Re: Antifreeze
I used the 50/50 mix from menards and it works great.. Good price too when onsale.
ModelAMike1930 is offline   Reply With Quote
Old 10-23-2017, 02:16 PM   #3
Bill G
Bill G's Avatar
I am using the same stuff I use in my family car, a 50/50 mix. Nothing special.
Bill G is offline   Reply With Quote
Old 10-23-2017, 02:30 PM   #4
Crankster
Crankster's Avatar
Some kind of anti-corrosion protection is necessary even if antifreeze isn't required, seems to me.
Crankster is offline   Reply With Quote
Old 10-23-2017, 03:05 PM   #5
René W
René W's Avatar
I use cooling fluid made for cast-iron blocks,it can get hotter before boiling as water,keeps the rust out and no anti-freeze needed
It is a pile of shit bit it's my pile of shit
René W is offline   Reply With Quote
Old 10-23-2017, 04:31 PM   #6
100IH
Interesting post. Distilled water is always good as it is not laden with minerals that can clog radiator tubes. Conventional coolants are concentrated and need to be diluted by 1/2, or 50/50. So it is better to use distilled water to dilute with. "50/50" is the same thing but it's being diluted to working strength so you don't have to. Concentrate works out to be cheaper - dilute it equal parts. Why pay extra to have someone add water?
100IH is offline   Reply With Quote
Old 10-23-2017, 05:13 PM   #7
old31
I use distilled water bought at the grocery store and Prestone yellow concentrate antifreeze. Usually Wallmart has the best price. Use a 50/50 mix.
Yes, you want antifreeze even if the car is not in freezing temps.
Old 10-23-2017, 06:09 PM   #8
Crankster
Crankster's Avatar
This applies to Light Beer as well.
Old 10-23-2017, 10:33 PM   #9
Smog Tech
Smog Tech's Avatar
Some in my club have had problems with antifreeze foaming. I use O'Reilly Conventional Green Antifreeze made for older cars (pre-1980). No problems for me. I do use distilled water to mix 50-50.
Smog Tech is offline   Reply With Quote
Old 10-23-2017, 10:41 PM   #10
Mike V. Florida
Mike V. Florida's Avatar
Sounds reasonable!
Old 10-23-2017, 11:17 PM   #11
Drive Shaft Dave
Don't forget to use conventional formula for use in vehicles with brass radiators. Prestone long life in the yellow jug not compatible.
Drive Shaft Dave is offline   Reply With Quote
Old 10-23-2017, 11:19 PM   #12
mike657894
mike657894's Avatar
50/50 green/water causes no issues. my car has sat with it in there for 40 years or more. changed occasionally of course. I use the mix your own out of habit
mike657894 is offline   Reply With Quote
Old 10-25-2017, 04:57 PM   #13
NCRebel
NCRebel's Avatar
I use a 50/50 mix in the radiator here in the Mississippi heat. I do refill with distilled water because of all the chemicals and minerals in the tap water. We don't get the winter weather most of you folks do.
NCRebel is offline   Reply With Quote
Old 10-25-2017, 05:24 PM   #14
1930artdeco
1930artdeco's Avatar
I bought some marine grade antifreeze because it is biodegradable. At the time I was losing water out the over flow tube and did not want to harm any thing. I will let people know how it goes.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
1930artdeco is online now   Reply With Quote
Old 10-25-2017, 07:27 PM   #15
glenn in camino
glenn in camino's Avatar
I keep my Model As in my heated garage when they're not on the road. Be careful with antifreeze. IT WILL REMOVE PAINT.
glenn in camino is offline   Reply With Quote
Old 10-25-2017, 08:46 PM   #16
goodcar
Antifreeze will seep through minute cracks in a block or through a marginally good head gasket whereas water won't. Not sure why that is, have read that it has something to do with water having a greater surface tension than antifreeze. I had an engine that ran cool, seldom added water but when I filled with antifreeze, started noticing it in the oil that leaked on the garage floor.
goodcar is offline   Reply With Quote
Old 10-25-2017, 09:36 PM   #17
duke36
There's been discussion elsewhere about the ethylene glycol ( green, etc.) vs. newer propylene glycol based antifreeze. The latter being less toxic and not as corrosive.
Can't remember which is more suitable in brass and aluminum cores. We use the 50/50 all compatible Sierra in the new Brassworks radiators and no noticeable effects so far.
duke36 is offline   Reply With Quote
Old 10-25-2017, 10:15 PM   #18
Bruce Adams
Bruce Adams's Avatar
I use 50/50 SIERRA Brand Coolant,Propolyne Glycol, available at ACE, with distilled water, which resists foaming and, if leaked, is not poisonous to animals.
Bruce Adams is offline   Reply With Quote
Old 10-26-2017, 12:42 AM   #19
Big hammer
More information please! This sounds to good.
get a bigger hammer tap done
Old 10-27-2017, 09:23 PM   #20
Lona
Lona's Avatar
If you have pets at home or neighbors who let their pets roam, it would be prudent to always use the non toxic antifreeze. A little more expensive but worth the peace of mind.
Glen
'31 Model A Deluxe Roadster
'31 Chrysler Model 70 Sedan
'88 Pontiac Fiero GT
'36 Auburn Boattail Speedster replica
Lona is offline   Reply With Quote
