03-16-2018, 07:11 PM | #1 |
31 Floor Cover Over the Rear Spring
When it comes to installing the cover over the rear spring that sticks up through the floor, how tightly is the cover pulled taunt over the spring?
Is it possible that the rear spring might raise up farther? Thanks for the help. |
03-16-2018, 10:27 PM | #2 |
Re: 31 Floor Cover Over the Rear Spring
Mine is made from scrap seat upholstery and top material it has loops sewn for the metal straps and sewn together from the corners to make a tent shape if I recall. not really tight over the crossmember.Ill pull the seat out and check it when im looking at the armrest for you...
03-16-2018, 10:37 PM | #3 |
That is the frame's rear crossmember that protrudes into the car and the body is attached to the frame so no additional protrusion will occur.
Bob Bidonde |
03-16-2018, 11:17 PM | #4 |
Bob is right, as the bump is part of the frame it cannot rise any higher than it already is.
03-17-2018, 05:25 AM | #5 |
Bill W.
