Go Back   The Ford Barn > The Swap Meet > Wanted > Early V8
Old 07-21-2012, 10:18 PM   #1
Nickster
Nickster's Avatar
Default Woodie Part
City: Paso Robles
State: California
Looking for a lift gate swing arm bracket for a 1946 Ford woodie. Need only one. This is the bracket that attaches to the rear corner pillar. Thanx
Nickster is offline   Reply With Quote
Old 07-22-2012, 10:25 AM   #2
39wdy
Default Re: Woodie Part
Hi, Bob drake has all of those parts in reproduction now; swing arms $65 a pair, lift gate swing arm bracket assemblies $82 (the part that goes on the window frame), and the bracket assembly that has the chrome knob to lock the rear lift gate window in the open position $80 (P. 541 catalog 27). I have these parts as well, they are original but you should know if you want the bracket with the chrome knob that mounts on the rear corner pillar there are two types. The more common one is 2 inches long from the mounting base with the three screw holes to the end of the threads where the knob mounts. The other type is 2 and 5/8 inches long (measuring the same way) and has a sort of double bend in the cast shaft. You can e-mail me at jen.toby@yahoo.com if I can help. Thanks, Toby Lampert
39wdy is offline   Reply With Quote
Old 07-30-2012, 05:12 PM   #3
Nickster
Nickster's Avatar
Don't need it.
Thread Tools
Display Modes
