08-14-2017, 08:57 AM | #1 |
Snyders Rebuilt Transmission
I just received a rebuilt transmission from Snyders. When getting ready to install it I noticed the baffle on the front ball bearing was missing. I also noticed that the bearing was not sealed. I assume the front side of the bearing was probably sealed. It is my understanding that if the baffle isn't used then the bearing needs to be sealed on both sides. I called Snyders regarding this issue and was told that there was not enough clearance to allow for the baffle, if the baffle was used it could lock up the transmission. I assume that probably has something to do with the particular gears they are using. I'm okay with all of this hoping that the outside seal doesn't fail but this just seems like departure from everything I've read regarding the assembly. The back ball bearing does have the baffle. I'm not trying to trash Snyders, have always been very pleased with them and will continue to patronize them but just want to point this out if someone else encounters this same situation.
08-14-2017, 11:26 PM | #2 |
Re: Snyders Rebuilt Transmission
That baffle is not used with a sealed bearing. Seems as though the seal was removed on one side. The side that is still sealed does not have the baffle. The raised portion of the baffle is what acts like the seal on the bearing.
08-15-2017, 07:40 AM | #3 |
Did you check both sides of the front bearing? You would have to remove the input shaft cover to see the front of the bearing. Many times, a builder will remove the rear seal of a sealed bearing and leave the front intact for oil control.
08-15-2017, 09:32 AM | #4 |
One of the functions of the shield is to prevent chips big enough to jam the bearings out of the bearings
08-15-2017, 09:39 AM | #5 |
Why not contacting the company who delivered/rebuilt the transmission ?
08-15-2017, 09:45 AM | #6 |
08-15-2017, 10:32 AM | #7 |
No I did not check the front side of the bearing. I trust that Snyders left it intact, they've rebuilt hundreds of transmissions over the years and I think if there was ever an issue such as I described, we would have probably heard about it by now. In other words, I have to give them the benefit of any doubt until proven otherwise. My initial impression was that this just didn't look right and called them to make sure there wasn't an oversight on their part and the baffle was accidentally left out. Without plowing through my original post, I'll just say that they did respond with an explanation.
08-15-2017, 10:39 AM | #8 |
From my original post: "I called Snyders regarding this issue and was told that there was not enough clearance to allow for the baffle, if the baffle was used it could lock up the transmission. I assume that probably has something to do with the particular gears they are using."
08-15-2017, 10:47 AM | #9 |
Don't know, if I could answer that question, I would have probably rebuilt the transmission myself, however, my skills when it comes transmissions are not up to that level which is why I left the rebuild up to someone else.
08-15-2017, 11:01 AM | #10 |
I remember from Tom Endys transmission tips that the baffle should be refitted regardless whether the bearings are sealed or not, the baffle is close to 0.040 what will happen without it is anyone's guess.
Nothing can be made foolproof, ---- fools are ingenious bastards. |
08-15-2017, 11:01 AM | #11 |
There were two sizes of oil baffles used front and back in the Model A transmission. The early housings that have machined bearing stops use baffles that are slightly smaller in diameter than those used in the housings that have snap ring stops. The service bulletins describe the change.
None of the suppliers offer the early oil baffles, only the later. If you install a later oil baffle in an early housing it will jam the transmission. Service bulletin reference: September 1929, Page 379. Tom Endy |
08-15-2017, 01:42 PM | #12 | |
08-15-2017, 02:43 PM | #13 |
Per Toms reply and his tips.I would think you would use the baffle. The rebuilder would need to use the correct size that dates your transmission.
08-15-2017, 03:16 PM | #14 | |
So what takes up the space that the baffle occupied?. Snyders should have a better answer than that given.
08-15-2017, 06:45 PM | #15 |
A good solution to your dilemma is go buy a Mitchel synchronize transmission.
08-15-2017, 07:05 PM | #16 |
08-15-2017, 07:23 PM | #17 |
my 31 was rebuilt 10 years ago,tranny has never leaked same as motor,rear end will have a dime size spot on floor in 6 months its the drain plug rather wipe it up than fix it
08-15-2017, 10:13 PM | #18 |
08-15-2017, 11:08 PM | #19 |
I usually always use the baffles as well as Tom Envy says . Peacemakers you use the correct one as per service bulletins . I have never assembled improperly to cause a pickup issue and have done countless transmissions .
I use a lightbulb to lightly preheat the bearings for. An easy install Larry Shepard |
08-16-2017, 08:16 AM | #20 | |
