Old 06-28-2015, 05:31 PM   #1
Kirk1963
Default Throttle not returning to idle
Hi guys, my throttle doesn't return to idle (I have to nudge the pedal up a bit) and sometimes I have trouble going into gear while moving - thinking it's related). Haven't had a chance to dig into it yet - is the return spring adjustable? Is this a common problem? Thanks!
Kirk1963 is offline   Reply With Quote
Old 06-28-2015, 05:41 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Throttle not returning to idle
Needs to be oiled on top/both ends have an oil area. no on the return spring may have lost its spring?
www.whidbeymodelaclub.com
Old 06-28-2015, 05:50 PM   #3
Kirk1963
Thanks Gary, I have definitely never oiled it - will check that thank you. It springs back just the last 1/4" or so it "sticks". Thanks again
Old 06-28-2015, 05:55 PM   #4
Jwilli
Jwilli's Avatar
Oil works wonders. Good luck.
Jwilli is offline   Reply With Quote
Old 06-28-2015, 06:46 PM   #5
burner31
burner31's Avatar
Also check to make sure the spring is not broke, can be a pain to change but easy once you get the floor up.
I had the same problem, turned out to be a broken spring on the accelerator shaft.
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 06-28-2015, 06:52 PM   #6
Mitch//pa
along with what has already been mentioned as possibilities ie tight shaft. weak or broken return spring,
check for floor board or mat interference
hand throttle lever linkage issue
and a worn throttle shaft will also cause it to hang a hair off the idle stop screw
Old 06-28-2015, 06:59 PM   #7
mrtexas
mrtexas's Avatar
Broken spring =WAO
mrtexas is offline   Reply With Quote
Old 06-28-2015, 08:38 PM   #8
Brentwood Bob
2tooth steering box, or 7tooth?
you may not be getting full travel because throttle lever is not getting full travel.
Also, when the engine is pulled the throttle assembly gets bent.
Bob
Brentwood Bob is online now   Reply With Quote
Old 06-28-2015, 09:00 PM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
Originally Posted by mrtexas View Post
Broken spring =WAO
What does WAO mean? thanks
Old 06-28-2015, 10:16 PM   #10
Mike V. Florida
Mike V. Florida's Avatar
According to internet slang, WAO means "Wow"
Old 06-28-2015, 10:39 PM   #11
SeaSlugs
SeaSlugs's Avatar
also ive seen worn carb shafts/butterflies hang up. might check those for slop.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 06-28-2015, 10:58 PM   #12
RandyinUtah
If you have a rubber seal nailed to the floor board that the linkage passes through it may be hanging up. It happened to me once after the car had been sitting for awhile.
RandyinUtah is offline   Reply With Quote
Old 06-30-2015, 09:00 PM   #13
LopezCarguy
LopezCarguy's Avatar
check floor board, it can interfere with gas peddle returning...
The only thing worth learning is what you learn after you know it all !!
LopezCarguy is offline   Reply With Quote
Old 08-21-2018, 12:49 AM   #14
hb32
hb32's Avatar
Very new to A`s and was having a similar problem. Spent an hour trying to Mac Gyver a secondary return spring and found this thread. Oiled as described by Gary WA and works like it was meant to be. Thanks posters on the Barn, my go to place for the right fix every time.
hb32 is offline   Reply With Quote
Old 08-21-2018, 06:05 AM   #15
JOHN CT
JOHN CT's Avatar
I had the same problem. Oiled the linkage problem solved!! Now when I oil the distributor a couple of drops goes into the linkage. But the difference I do is I use the 600 weight oil. It doesn’t run out of it and make a mess. What do you folks think about using 600 weight oil?
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
Old 08-21-2018, 07:56 AM   #16
Ray in La Mesa
Every throttle linkage I've seen has bent bent in some way. Double check ALL along the length of the linkage and watch how it rotates, there are only about 75 ways it can be bent!
Ray in La Mesa is offline   Reply With Quote
Old 08-21-2018, 08:39 AM   #17
100IH
What Ray said.
100IH is offline   Reply With Quote
Old 08-21-2018, 09:38 AM   #18
Bill G
Bill G's Avatar
WAO is just as easy to spell/ just as many keystrokes or key taps as wow.... And that's slang?
I am not saying its not, but oh well... All I can say is WAO!
-Bill G
Member of Walla Walla Sweet A's Model A Club
Bill G is offline   Reply With Quote
Old 08-21-2018, 01:50 PM   #19
Charlie Stephens
I am attaching photos to show one of the two oil points that the other posters are referencing. It may be being missed since it doesn't look like a place to put oil unless you are looking for it.
Charlie Stephens
Old 08-21-2018, 08:32 PM   #20
SeaSlugs
SeaSlugs's Avatar
Sure cant hurt. It will eventually flow around the shaft. ANy lube is better than no lube in this case.
Thread Tools
Display Modes
