Old 09-26-2013, 11:40 PM   #1
buddyholley19
Default Has anybody tried a new zenith carb from snyders
What would you experts do? Buy a new Air Balanced Zenith Carburetor
From snyders and get the old zenith rebuilt to keep as a spare , or just rebuild the old one.....My hot rod friends all say get a new one .I wanted to ask you guys first ... Any advice would be much appreciated.
buddyholley19 is offline   Reply With Quote
Old 09-27-2013, 12:13 AM   #2
montanafordman
montanafordman's Avatar
Default Re: Has anybody tried a new zenith carb from snyders
It sure seems you can find some nicely rebuilt ones for about half of what they're asking for a new one if you don't want to give a shot at rebuilding it yourself. My pockets aren't that rich but its your car! $450 just seems like a LOT to spend on a carburetor!
Aaron in Tacoma
(although still a Montana hillbilly at heart )
montanafordman is offline   Reply With Quote
Old 09-27-2013, 12:53 AM   #3
Tiny
Tiny's Avatar
Some people just like to spend money. I like to learn how to rebuild things properly. I'm sure it's a great product as Snyders is a quality company. Goodluck
Tiny is offline   Reply With Quote
Old 09-27-2013, 05:36 AM   #4
Mitch//pa
A. Rebuild it yourself with a viton valve, renners corner flow tested jet set, and an oversize throttle shaft if yours has play.
B. purchase a rebuilt from Berts have heard good reports and they are priced right
Old 09-27-2013, 11:27 AM   #5
Russ/40
Russ/40's Avatar
Get one of the units sold by "Tazman" on eBay. He is a neighbor of mine and does super work. Test drives every one on his coupe before it ships. Or contact him about doing your core.
Russ/40 is offline   Reply With Quote
Old 09-27-2013, 11:34 AM   #6
Rowdy
I have heard good things about Bert's rebuild kits also. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 09-27-2013, 12:00 PM   #7
zmjc
Do you mean the user "novaki" on Ebay? Tazman appears to sell Star Wars figurines, no carburetors...
zmjc is offline   Reply With Quote
Old 09-27-2013, 12:00 PM   #8
pat in Santa Cruz
pat in Santa Cruz's Avatar
we use a lot of rebuilt Zenith carburetors from Berts and are very happy with them. OTOH, the V8 guys are using repro Strombergs and Holleys and are very excited about them. Seems with time, the castings wear out and deteriorate, so new is better in their experiences. But Zenith castings are iron, so deterioration is not as big an issue although it does happen. I would feel pretty confident with a good iron casting rebuilt by Berts.
pat in Santa Cruz is offline   Reply With Quote
Old 09-27-2013, 01:27 PM   #9
Ross/Kzoo
Ross/Kzoo's Avatar
I finally bit the bullet and retired my Tillotson and threw on a rebuilt Zenith from Bert's. No problems, started right up and haven't looked back.
Ross/Kzoo is offline   Reply With Quote
Old 09-27-2013, 01:40 PM   #10
newshirt
newshirt's Avatar
I'm not an expert, so I bought a rebuilt from Bert's. It made the car run like new! Now I have my old one to tinker with. I'll probably try to rebuild it myself using Tom Endy's excellent instructions. Thanks, Tom!
Available from two sources:
http://www.ocmafc.org/techarticles/T...%2011-2007.pdf
http://modelabasics.com/Carb/ZenithC...l2011-2007.pdf
Ray White
newshirt is offline   Reply With Quote
Old 09-27-2013, 02:26 PM   #11
30Murray
I suggest you contact a member of Lions Gate Model A Club who does high quality carb rebuilds. You can find his name here (scroll down to the bottom of the page) http://www.lionsgatemodelaclub.com/Suppliers.html
30Murray is offline   Reply With Quote
Old 09-27-2013, 02:29 PM   #12
Bob-A
Bob-A's Avatar
Question Re: Has anybody tried a new zenith carb from snyders
"Air Balanced..." I like the sound of that! And, I sure would like to
see what they did to the carburetor to make it that way?!? I know all about the theories concerning air balanced Model-A carbs. too. I just
want to see how they do it.
Bob-A
Bob-A is offline   Reply With Quote
Old 09-27-2013, 02:53 PM   #13
Dave in MN
Dave in MN's Avatar
I have only heard good things about the air balanced carb from Snyder's. Using it allows you to use an air cleaner without altering the gas/air mix. I also heard testament that the achieved fuel economy is also good...over 20 mpg.
Good Day!
Dave in MN is offline   Reply With Quote
Old 09-27-2013, 03:46 PM   #14
Russ/40
Russ/40's Avatar
Different guy. He has added to his name some numbers. He has sold over a 1000 of them over the years.
Tazman24282428 is his name.
Old 09-27-2013, 04:19 PM   #15
Skibb
Skibb's Avatar
TAZMAN sold me via eBay a Zenith carb that the he Boldly claimed was rebuilt and worked for extra air and super performance. Guess what: the carb is a jewel. It's performance is Outstanding Sir.
Skibb is offline   Reply With Quote
Old 09-27-2013, 04:23 PM   #16
Rowdy
Here is the old school way to air balance. Rod
Old 10-11-2013, 01:13 PM   #17
John of White Rock
I have a nearly new air balanced carb that someone brought me to rebuild since it didn't work very well. They ended up buying an original zenith rebuild from me and were very pleased that their car ran so well. I kept the air balanced carb just to see what it was all about, quite ingenious actually with internal machining & casting to provide a connection between the float bowl and the air horn. I ran this new carb on my Phaeton and it was a very rough go. Decided not to fool with it and to stick to the original Zeniths that work so well when properly done. I would gladly part with the new, air balanced carb if someone would like it. John Haddon, 604-538-1938, bjhaddon@telus.net
John of White Rock is offline   Reply With Quote
Old 10-11-2013, 01:23 PM   #18
P.S.
I'm also a fan of the Bert's rebuilt Zenith carburetors. I got the first one after throwing a hissy-fit about some other rebuilt carbs I tried that sucked. Steve went out on a limb and sent the carb to me and said to run it and return it if not satisfied. Couldn't go wrong, so did just that. The new carb ran (and still runs) so well, I refused to send it back, I sent a check instead!
I have since purchased another one from Bert's as a backup. Haven't needed to use it, but just feel better knowing it's there. I won't mess around with anything else now, I'll ONLY run a Bert's rebuilt Zenith. Everyone that hears my car run marvels at how smooth and powerful it is.
P.S. is offline   Reply With Quote
Old 04-06-2014, 09:03 PM   #19
freak
freak's Avatar
Old post I know but based on what you said I bought an air balanced Zenith 1 from Tazman. Just got it installed last week and it looks and works great.
freak is offline   Reply With Quote
Old 04-06-2014, 10:21 PM   #20
John
John's Avatar
Let me know about the air balanced carb. I might be interested if we can work a deal.
John
John is offline   Reply With Quote
Thread Tools
Display Modes
