01-12-2018, 12:17 PM | #1 |
Parts identification help
I ended up with some parts I have two headlights which I believe are both 1932 Ford however, one has a hole on top for a turn signal and a hole for the third wire in the base. The only other difference is the rivers in the bottom, one has flat head rivers and the other has rounded head rivers.
I also have a pedal assembly which I thought was 1932 as well. The parts were all labeled as 1932. Last edited by 19sc29; 01-12-2018 at 03:27 PM. Reason: Added pics of pedals. What year are they for? |
01-12-2018, 12:20 PM | #2 |
Re: Parts identification help
headlights look like aftermarket either guide, or blc. guide are usually stamped some where
01-12-2018, 12:43 PM | #3 |
I’ll have to check it out. I was honking they could be aftermarket because the way the 12 volt headlight fits in. It would have been a reflector with a lens factory.
I have to take a quick pic of the pedal assembly. That’s for mechanics brakes and I know it’s a factory piece, just not certain of the year. |
01-12-2018, 02:12 PM | #4 |
Not Ford.
01-12-2018, 03:28 PM | #5 |
Thanks, how about the pedals? Any idea?
01-12-2018, 04:00 PM | #6 |
01-12-2018, 05:35 PM | #7 |
Pedals or mount should have some numbers on them? Would help identify them.
01-12-2018, 06:10 PM | #8 |
I’ll have to take a look for the numbers. Thanks guys.
01-12-2018, 06:13 PM | #9 |
Not to pile on, but the lights are definitely not Ford original equipment and as deuce lover indicated, the pedals are '32, but for big trucks (they are a very early version thereof).
01-12-2018, 07:37 PM | #10 |
Thank you guys. Just trying to identify the parts. The pedals will probably go up for sale so someone who needs them can use them. The headlights I’ll keep for a hot rod. Thank you guys.
01-12-2018, 07:51 PM | #11 |
The Headlights are aftermarket.
They are Arrow 775 lights.Made in Mt Holly NY. It will be stamped on the top of the headlights |
01-13-2018, 04:42 PM | #12 |
X2 on the headlights.
