11-17-2018, 08:51 AM | #1 |
Trunk Lid rubber parts
Looking to find 2 Deck Drain Plug Rubbers Located toward the bottom corners on the Deck Drain Trough (deck drain) assembly, are two holes, left and right, for which the arm (deck door hinge) and base assembly, left and right, were attached for the attachment of the hinges for the Deck Door Rumble Seat assembly. See pictures (provided by Marco Tahtaras and Steve Plucker) .. |
11-17-2018, 12:19 PM | #2 |
Re: Trunk Lid rubber parts
Have you ck'd with Restoration Supplies in Escondido, CA?? They have a web site.
Paul |
11-18-2018, 02:02 PM | #3 |
Thanks Paul
Checked there website but non available :-(( |
11-18-2018, 02:36 PM | #4 |
Metro Rubber in the Twin Cities makes lots of rubber parts for older cars and trucks.
11-18-2018, 05:30 PM | #5 |
The large ones, you can get from the vendors. You will probably have to grind the tops of them down a little to make the lid fit closed. The small ones I made for myself. If you cannot find any that are close to the spec I will make you some. Dale. |
