08-14-2018, 10:45 AM | #1 |
'36 Window Regulator Restoration Question
I'm looking for advice on restoring the window regulators on my '36 3W. I removed them about 6-years ago when I started to restore the car and just removed them from their storage box last week to take some pics for another thread. I decided that as long as I had them out, I might as well start on them.
I removed the two springs and started washing off the years of grease & dirt on them and all the paint that was on them washed off with the solvent, so now I'm committed! Everything else on the assembly appears to be rivited on to the mounting plate. To be able to get to the back of the gears to paint them, I'd have to drill out all the rivits, clean & paint, then try to rivit everything back together or bolt things together. Looking for suggestions / ideas on how others have restored these assemblies. Thanks, -Bob |
08-14-2018, 12:57 PM | #2 |
Re: '36 Window Regulator Restoration Question
Clean them, repair any issues, paint them, crank them around when dry, paint the missed spots, oil them a little, and put aside for installation.
Taking them apart any more than needed for repair is not necessary. Don't worry about any small unpainted areas. |
08-14-2018, 01:43 PM | #3 |
I took my convert sedan ones apart, replaced drive gears, welded up teeth---- then I bought NOS, sold the repaired ones for twice what I paid for nos--- then I started on the door latches, --- carpenter had nos for less than springs cost, did take some searching for that last left front one though------ many time it costs less for nos than parts/ labor to fix old ones, and you end up with better operating
08-14-2018, 03:35 PM | #4 |
OK, thanks for the responses. Guess I was over-thinking things again.....
Thanks, -Bob |
08-14-2018, 04:24 PM | #5 |
