09-15-2019, 09:50 PM | #1 |
Ignition timing
1947 59A standard ignition
Looking down on the distributor sitting on my bench. The vacuum brake is at the top. The right ignition point gauges at about .015. Which is in spec. The left one, however, gauges at .009 or a little less. What effect does the smaller gap have, if any, on the timing? What effect does the smaller gap have, if any, on anything else? |
09-16-2019, 07:08 AM | #2 |
Re: Ignition timing
Smaller gaps delay or retard timing. Gaps too small can reduced point life and foul or shunt as a result of corrosion/erosion/dirt.
09-16-2019, 07:37 AM | #3 |
Re: Ignition timing
The points are NOT set with a feeler gauge. They are
on a Ford~Heyer strobe machine on a dwell meter. G.M.
www.fordcollector.com |
09-16-2019, 08:43 AM | #4 |
Re: Ignition timing
There are other ways to do this, such as a sun distributor machine or a k. r. Wilson timing fixture. My ford service manual calls for .014 to .016 setting and shows how to set the points using a straight edge.
09-16-2019, 09:47 AM | #5 |
Re: Ignition timing
When set up on a sun machine,the right points are adj. to an initial dwell with the left ones blocked off with a piece of fiber such as a match pack. That is then removed and the total dwell is set buy adj. the left set.
09-16-2019, 03:37 PM | #6 |
Re: Ignition timing
09-16-2019, 09:09 PM | #7 |
Re: Ignition timing
Anyone have a pic of the straightedge method? I remember seeing it in one of the books I have somewhere. Thanks
09-16-2019, 09:36 PM | #8 |
Re: Ignition timing
Some of the early edition Motor Manuals have it in them probably before 1949.
Those manuals dont bring a lot of money |
09-16-2019, 09:38 PM | #9 |
Re: Ignition timing
Look on VanPelts site.
09-16-2019, 11:23 PM | #10 |
Re: Ignition timing
Here's some tips
http://www.btc-bci.com/~billben/flathead.htm Distributor timing .32to 48 timing fixture don't need em , |
09-16-2019, 11:57 PM | #11 |
Re: Ignition timing
If you are using quality points although not ideal you could set them by gap not dwell. If you are using cheap quality points it’s a crap shoot. Send it to someone with a sun machine and for little to no money they can adjust to the proper dwell and set the timing.
09-17-2019, 05:17 PM | #12 |
Re: Ignition timing
There are static jigs around for setting the dwell, there are two on ebay now,exspensive though.
keep a lookout for them . Lawrie |
09-17-2019, 07:29 PM | #13 |
Re: Ignition timing
I am a poor guy, I set mine with a set of feeler gauges, like my Dad did before me all the way up till mid 70s when Dad 75 Lincoln.
09-17-2019, 07:36 PM | #14 |
Re: Ignition timing
Ya' know, I was in your camp until about 3 months ago, when I replaced the points on the Mallory dual point on the '51 Merc in my '51 Ford. For some reason, that particular setup didn't have the little slots they usually have where you can insert a small screwdriver to move the points a little bit at a time. I bought an old universal dwell/tach meter off of eBay for $20. Now I realize I should have done it 50 years ago.
09-18-2019, 09:45 AM | #15 |
Re: Ignition timing
One of the problems in these discussions is terminology.
TIMING an early flathead distributor is a little different than TESTING a distributor. TIMING involves setting the dwell and adjusting the initial advance. TESTING means checking the distributor for wear, bad parts, faulty operation, etc. TIMNG and TESTING can be done at the same time ... with aging distributors and questionable new parts, it's a good idea. BUT, claiming that one cannot TIME a flathead distributor using feeler gauges to set the dwell ... ? THINK about it. Ford designed, patented and produced the distributor with the intent of having points set with feeler gauges. Ford did not design it so that owners had to send their distributors to G.M. and Skip Haney to be timed.:roll eyes: The misinformation, much from using the wrong descriptions, has given the distributors a bad reputation. Am all for testing distributors. But, when someone asks how to time one, please give a knowledgable answer.
"Remember that when it comes to intelligence, half of all of us are below average." |
09-18-2019, 09:54 AM | #16 |
Re: Ignition timing
Hoop i would agree with that last part if all we used were genuine Ford parts. Ever set up a 32-36 with a feeler gauge using reproduction points and checked the dwell?
The 49 and later guys and 4/6 cylinder guys should have no issues using a feeler gauge to set dwell |
09-18-2019, 10:19 AM | #17 |
Re: Ignition timing
Michael,
The "knowledgable answer" would include exactly what you've said. Further, there is no guarantee that sending your distributor out for rebuilding will have it TIMED correctly. That includes units that have been "set up" on Sun or Allen strobers and the rebuilder does not understand initial advance. There are a bunch of guys running around losing 20% or more of their advance because of improper settings. I know you are well aware of the issue and that distributors leave your shop correctly set.
09-18-2019, 10:27 AM | #18 |
Re: Ignition timing
Hoop,
Yes I agree. I tested many “rebuilt” distributors that the initial timing was not set they just seemed to guess at it. |
09-18-2019, 10:34 AM | #19 |
Re: Ignition timing
That's how I do it. Also what Bubba recommends.
09-18-2019, 12:14 PM | #20 |
Re: Ignition timing
Also the way Ford recommends.
