05-19-2019, 02:04 PM | #1 |
Juice brake question
My mechanical brakes have been replaced with '40 backing plates, hubs and drums and mounted on '48 spindles. The spindles have had damage and welding on them. I found a nice pair of '37 spindles. Will these work with my '40 brakes and hubs?
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
05-19-2019, 02:19 PM | #2 |
Re: Juice brake question
yes, same bolt pattern 37 to 48
05-19-2019, 08:24 PM | #3 |
05-21-2019, 03:44 PM | #4 |
Just beware that you must use '37-'41 king pins. King pins always match the year of spindles. And the tapered hole in the passenger side for the drag link will be tapered opposite the '48 taper. In other words, the drag link will install on the BOTTOM side of the arm on the '37. Taper is the same 7 degrees, though. DD
05-21-2019, 11:21 PM | #5 | |
