11-27-2018, 02:15 PM | #1 |
Stuck oil Pan
Guys , I need some ideas on how to get my oil pan to drop down . trying to remove it , but I think I put too much gasket sealer on it last time , [ but I didn't have any leaks ] , now I cant get it loose . trying not to do any damage to the block . Cant find anything in a search . Watch ya got ? Forgot to add that engine is still in car .
11-27-2018, 02:28 PM | #2 |
Re: Stuck oil Pan
Plastic or wooden wedges placed in several locations around the pan will likely free it up. Wooden wedges can be made on a bandsaw out of hardwood scraps.
11-27-2018, 03:38 PM | #3 |
Re: Stuck oil Pan
Try some Heat with a propane torch.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
11-27-2018, 03:40 PM | #4 |
Re: Stuck oil Pan
Sounds like you will destroy the gasket by the time you get it off. Don't worry about that - they are cheap. Just scrape the surfaces clean and use your sealer on one side only when you reinstall. Brent's suggestion is good but my advice is to use several wedges and work your way around them in turn so you don't distort the sump.
11-27-2018, 05:17 PM | #5 |
Re: Stuck oil Pan
A putty knife works nicely to unseal a gasket.
11-27-2018, 05:24 PM | #6 |
Re: Stuck oil Pan
Use Permatex #2 Non Hardening Form-A-Gasket Sealant on new gasket. |
11-27-2018, 06:24 PM | #7 |
Re: Stuck oil Pan
Just for kicks, double check that all the bolts are out. It can happen.
I think some putty knives should work also. Good luck. |
11-27-2018, 06:49 PM | #8 |
Re: Stuck oil Pan
Thanks for all the replies guys , I knew this was the place to go . All good ideas , this pan is coming down now . I like the wedges and putty knife ideas . I think I had a senior moment today when I was trying this , hate it when that happens .
11-28-2018, 09:54 AM | #9 | |
Re: Stuck oil Pan
11-28-2018, 12:39 PM | #10 |
Re: Stuck oil Pan
Try an Olfa Knife (Box Cutter)
11-28-2018, 08:42 PM | #11 |
Re: Stuck oil Pan
Had this happen on a coupe I bought. Tried all of the ideas to no avail. Ended up a lady tool & die maker from the west coast who was on the barn years ago (don't recall her name or avatar) told me to cut off a putty knife blade as the handle wouldn't fit between the pan and the frame rails. That gave me enough room to slightly swing the side of a hammer against it. It worked a few inches at a time and I got the pan off. Whatever a PO used was black and hard.
11-28-2018, 09:57 PM | #12 |
Re: Stuck oil Pan
The lady tool and die maker may have been Carla .
11-29-2018, 09:36 PM | #13 |
Re: Stuck oil Pan
11-29-2018, 10:38 PM | #14 |
Re: Stuck oil Pan
Heating with a heat gun would be my suggestion.
11-30-2018, 12:23 PM | #15 |
Re: Stuck oil Pan
Why not save your fingers and simply buy a small bundle of the hardwood wedges sold at Home Depot, et al, that are used to level up door and window frames. Usually 1.5 X 6 inches and 3/8 inch tapering down to a blade edge and cost a few bucks for 10 wedges. Perfect for the job and I have also used them to pry loose a coupe body that was stuck to the frame.
11-30-2018, 11:39 PM | #16 | |
Re: Stuck oil Pan
