03-22-2021, 04:01 PM | #1 |
My 46 truck hates RPM
Changed coil. A bit better, but not much at RPM over 1800. 3 coils all same, HOWEVER is there a coil thats best? What plug is best to not foul in 6v
03-22-2021, 04:03 PM | #2 |
Re: My 46 truck hates RPM
NGK B-6L now but they went through the shop tuning process
03-22-2021, 05:29 PM | #3 |
Sounds like it could be ignition point bounce or "float" what brand of points are you running
03-22-2021, 05:40 PM | #4 |
Whats your vacuum reading ? Compression checks out near equal ? Plenty of fuel ? Clear exhaust ? Does it stall or just refuses to go higher rpm ? What tach are you using and is it reading correct ?
03-22-2021, 05:44 PM | #5 |
You need to check the point dwell on both sets of points. Must be correct for proper coil saturation.
03-22-2021, 06:01 PM | #6 |
03-22-2021, 11:42 PM | #7 |
You done a compression check? Check the condition your condition is in.
03-23-2021, 12:15 AM | #8 |
Changing your coil three times will not prove anything. I would remove the distributor and check the contacts and settings and contact spring tension etc. Also could be a lack of enough fuel problem as in low float level or blocked fuel filter or some such. Seems a lot of guys always blame the ignition coils which in fact dont give all that much trouble really. Regards, Kevin.
03-23-2021, 12:21 AM | #9 |
You've had two excellent answers, point float and fuel starvation. Both causes can produce the same symptoms, so much so that flip a coin to decide which to investigate first.
Alan |
03-23-2021, 08:50 AM | #10 |
Given the rapid up swing in door contact shockings I'm going points
03-23-2021, 09:47 AM | #11 |
03-23-2021, 09:52 AM | #12 |
