09-27-2011, 12:29 PM | #1 |
how do you remove interior door handle?
How the heck do you remove the interior door hand and window crank on a 51 tudor?
I know on the 60-70 stuff you use a shop towel and saw it around, but it isn't working on the 51. |
09-27-2011, 12:36 PM | #2 |
Re: how do you remove interior door handle?
You should be able to push the upholstery in far enough to see if you have a horseshoe clip or a pin. Then act accordingly.
09-27-2011, 02:24 PM | #3 |
51 has the wire clip. I used a thin rag like an old t shirt that will snag on the end of clip
09-27-2011, 02:28 PM | #4 |
