Old 06-20-2011, 12:09 PM   #1
grizz
Default engine noise discovered?
51 with the flathead six has a metallic knock when winding the engine thru the
gears. Cant hear it at idle or low speeds. I pulled the engine to find the cause
and after removing the starter i found the bendix spring was broken. I hate to
fix the starter and reinstall the engine and still have the noise, but also dont want to disassemble the engine needlessly. Would this make this type of noise
and does anyone have first hand experience? thanks
grizz is offline   Reply With Quote
Old 06-20-2011, 02:17 PM   #2
ford1
Default Re: engine noise discovered?
a broken bendix can cause all kinds of strange noises as it is bounced back and forth between the flywheel and starter, if the engine is out pull the pan, thats easy, and check the condition of the rod bearings, and main bearings, if a lot of miles on the engine now would be the time to replace them, just my oppion
ford1 is offline   Reply With Quote
Old 06-20-2011, 02:38 PM   #3
Mart
Mart's Avatar
I'm thinking the noise would be lighter and higher frequency than a metallic knock. Look at the ring gear teeth - do they look like they have been contacting the broken spring or bendix?
Look for evidence on the spring for contact - it should be all shiny and knocked about if contact has been made - if old/crusty/rusty/dirty it is not the source of the noise.
Mart.
Old 06-20-2011, 03:22 PM   #4
Mike51Merc
Mike51Merc's Avatar
If it was me, I'd see if I could beg/borrow/steal and engine test stand.
Mike51Merc is offline   Reply With Quote
Old 06-20-2011, 07:19 PM   #5
Jack 34pu
Jack 34pu's Avatar
I had a slight deep sounding knock in an engine with low miles a few years back. It started at 50 mph and the more I drove it, the knock came in at lower speeds. One day I decided to pull the motor and check it out. It was a floating rod bearing that had split at the oil groove and the chips caused some mid damage to the bearing and crank journal.
Jack 34pu is offline   Reply With Quote
Thread Tools
Display Modes
