Old 04-27-2019, 05:48 AM   #21
tubman
tubman's Avatar
Default Re: Radiator Shroud on a 1941 Pickup
I will add that the differential between the top and bottom of the radiator is a good indicator of the radiators performance. Anything less than 25 degrees (Fahrenheit) is an indication of a radiator not doing it's job.
Old 07-18-2019, 06:35 PM   #22
Fritz
Fritz's Avatar
Originally Posted by Charlie ny View Post
I will mention here that the shroud on my '41 did help quite nicely. The crank mounted
fan on these vehicles is far from centered to the radiator. Prior to the shroud I tried
the rag on the radiator stunt, it fell right off, with the shroud in place the rag clung
to the rad ( engine running fan spinning in both cases of course ).....anyhoo it worked
for me.
Charlie ny
Hey Charlie, can you post or send me a few pictures of how you installed the shroud and secured it to the radiator? I also have a 41 with the original radiator.
Fritz is offline   Reply With Quote
Thread Tools
Display Modes
