Old 10-02-2019, 02:34 PM   #1
New24ords
Default Converting park lights to signal on 49 f1
What are you guys doing to have both park lights and signal on the front of the 49 f1
New24ords is offline   Reply With Quote
Old 10-02-2019, 06:08 PM   #2
alanwoodieman
Default Re: Converting park lights to signal on 49 f1
put double element sockets/bulbs in the parking light. I went to the local auto parts store and purchased the metal plug in replacement lights, remove the single element fixture, put the double element metal can in and flattened the spring prongs and soldered it to the light housing, used amber bulbs and it works great!!
alanwoodieman is offline   Reply With Quote
Old 10-02-2019, 08:50 PM   #3
New24ords
Sweet thanks
Old 10-03-2019, 12:49 PM   #4
Ross F-1
Ross F-1's Avatar
The more common dual-filament bulbs (1154 in 6v) can end up right against the lens. Make sure you set the new sockets back enough to clear. There is some bulb that is noticeably shorter but I can't find it in my notes.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
