03-06-2019, 05:35 PM | #1 |
Cut out wire?
I picked up this original cutout. Is there suppose to be a wire attached were the arrow is?
If so, then were does the other end of the wire go to? |
03-06-2019, 06:28 PM | #2 |
Re: Cut out wire?
That allows the primary to be grounded on one end...
03-07-2019, 07:44 AM | #3 |
Re: Cut out wire?
If you don't see the fine wire at the solder joint, then look for a fine wire close to the coil, and hopefully you can solder it to ground. When the charge circuit is open, the generator can reach up to 40 volts, and that can burn off the fine wire.
03-07-2019, 11:34 AM | #4 |
Re: Cut out wire?
Tom, are these the 2 points that should be soldered together?
03-08-2019, 12:44 AM | #5 |
Re: Cut out wire?
Thread Tools | |
Display Modes | |
