01-25-2019, 01:18 PM | #1 |
pressure plate adjustment
how do you do it , what is the procedure . thanks, sc
01-25-2019, 01:50 PM | #2 |
Re: pressure plate adjustment
I am not sure of the reason why so many like to do this, but to do it correctly involves a flat surface and a height gauge. Is there a reason why you are wanting to do his?? Is there an issue or is this just something you would like to do?? |
01-25-2019, 11:12 PM | #3 |
Brent, what do you use as the desired setting? Some of our club members have purchased pressure plates that have WAY different measurements on the fingers than what show in the books. Some had variations of 1/4 inch in the finger lengths on the same pressure plates. That may be the reason for the original question.
01-26-2019, 07:02 AM | #4 | |
01-26-2019, 10:08 AM | #5 |
Both Bratton's and Snyder's (and probably others) say to adjust the pressure plate in their on-line catalogs. Bratton's even sells a height gauge.
I think as Brent says that the main thing is to ensure they are all the same. |
01-26-2019, 11:12 AM | #6 |
01-26-2019, 12:03 PM | #7 |
Using a clutch disk alignment tool, line up the clutch disk in the flywheel. Bolt on your pressure plate. Measure the distance from the back of pressure plate to the pressure plate fingers. Adjust the depth of the fingers to either 5/8" or 11/16".
01-26-2019, 12:11 PM | #8 |
New pressure plate (V8 clutch) from Brattons had not only perfect finger heights but was also balanced!
01-26-2019, 01:36 PM | #9 |
I don't have a problem with setting the fingers at either 5/8 or 11/16 as long as there is no more than .002" variation.
I don't use a height gauge as such, I use a piece of round stock turned to the diameter [ 5/8 or 11/16] wanted. Then just adjust each finger to an equal drag on the round stock. Give each finger a couple love taps and check/set it again. |
01-27-2019, 10:23 AM | #10 |
Do I understand that the suppliers are selling pressure plates that are incorectly adjusted and they expect the customers to make the corrections? Sounds like going to a deli and ordering a sandwich and they hand you two pieces of bread and a bag of cold cuts.
01-27-2019, 11:24 AM | #11 |
Often, new p/p assemblys have the nuts staked so that they will break before breaking loose.
01-27-2019, 12:23 PM | #12 |
The only vendor I am aware of that adjusts rebuilt pressure plate fingers prior to shipping is Bert's Model A Ford Center. When you receive the pressure plate from Bert's, you can just bolt it on. I have installed more than one and speak from experience.
This adjustment is critical. My first installation of a pressure plate and clutch disk was 16 years ago and was purchased from a different vendor. I was a newbie and unaware of the pressure plate adjustment. The installation was a total failure. I ended up replacing a failed pressure plate and throw out bearing after 1,000 miles. |
01-27-2019, 04:30 PM | #13 | |
I think this is where I may have misunderstood as I don't think I have ever installed a new Model-A style pressure plate since rebuilding one is more economical. I probably have 10+ original cores now on the shelf and have scrapped way more original-style P/Ps than I could ever count just because of converting to the V-8 P/Plates. My point above was, -and to confirm what others have already suggested is that anything between 0.625 - 0.750 is fine. Where the critical measurement that I did not see discussed above is the step measurement of the flywheel. The finger height adjustment is affected by this measurement which is 1.125' if I recall correctly (-someone needs to verify this to make sure.). Otherwise, anywhere in the range of 0.625-0.750 is going to be fine as long as all fingers are of uniform compressed height. |
