12-09-2017, 11:53 AM | #41 |
Re: "Angle Milling" heads
Which is why they have horse races.
03-12-2019, 11:46 AM | #42 |
After having built many ohv engines I always run the eng for aprox 20 min to break in the cam. The only oil the cam and lifters get is splash off the rods. Always be sure the eng will start within a couple of turns . Cranking and cranking on a eng will only wear the lube off the cam and lifters.
This works for me. Thanks Tubman. |
03-12-2019, 02:02 PM | #43 |
When It comes to piston clearances, I'm only concerned with the circumference area of the piston. not the center. Due to the difference in dome radius in both pistons and heads, all your looking for is an area that will furnish the "Squish" just before the spark plug fires, thus burning more of the F/A . Most modern engines use aprox. 1/2 " of the outside diameter of the piston.
03-12-2019, 07:47 PM | #44 |
03-12-2019, 07:58 PM | #45 |
03-13-2019, 09:34 AM | #46 | |
If you cant afford to do it right the first time... How can you expect to afford to do it right the second time?? |
03-13-2019, 10:31 AM | #47 |
Apparently no one paid attention when I covered the subject of ANGLE MILLING in my book. I explain some procedures and discuss what to do about the stud holes and spot faces. I am particularly surprised at Ol'Ron for not remembering.
03-13-2019, 10:42 AM | #48 |
JWL if i send you a check can you actually give some solid advice about how to solve issues instead of promoting your book as answer to all questions...
We all know you wrote a book...so did Ol´Ron but he actually do share his knowledge here... |
03-13-2019, 10:54 AM | #49 | |
In short, it was done right the first time so it won't have to be done a second time, as witnessed by the way the engine runs. Check out the video included earlier in the thread and you will see this. |
03-13-2019, 12:18 PM | #50 |
Thanks for the reminder, JWL. I was about to ask what procedure to use. I got your book several years ago, but totally forgot you covered angle milling. I imagine you get tired of being asked the same questions repeatedly when your book covers so much.
03-13-2019, 12:34 PM | #51 |
JWL's comments, while appreciated, are not germane to this discussion. I used it to correct a problem probably caused by a carelessly done previous decking. Remember, "end to end", not "side to side".
"Ol' Ron" wasn't "not remembering"; he had followed this thread carefully enough to realize what I was actually trying to accomplish. He knew that what I was doing would bring the bolt holes in the head back to their proper orientation and that they would need no further work. Last edited by tubman; 03-13-2019 at 12:42 PM. |
03-13-2019, 03:10 PM | #52 | |
03-13-2019, 03:26 PM | #53 |
Thank you "40 Deluxe". This was a very successful process for me, and I thought that the procedure I went through might be helpful or at least of interest to others. This thread has been sitting here for over a year as what I thought to be an excellent example of the lengths we sometimes have to go to in order to get these old beasts to the best running condition they can be. I thought twice about jumping in, but I felt I had to, since the whole thrust of the thread was being subverted by a couple of guys who didn't take the time to read the complete thread and comprehend it.
I think we should drop it now. |
03-13-2019, 03:57 PM | #54 |
Excellent decision.
03-13-2019, 08:42 PM | #55 |
we cover so many problem people have with these engines. Every six months or so we do it all over again. Allot of books have been written about this engine over the years and everything gets covered here on the barn, BUT! in six months we'll start over again. In my opinion I think Johns book is the best one written so far, wish I wrote it.
03-13-2019, 10:42 PM | #56 |
Agreed.
03-14-2019, 10:07 AM | #57 |
Lots of ways to skin a cat . . . and many opinions from the "skinners" to go along with them. You have an engine you're really happy with - that is what counts!
03-14-2019, 10:40 AM | #58 |
03-15-2019, 11:16 AM | #59 |
Sorry....sigh..... I read page one and didn't realize you had already milled the head to correct the deck being milled incorrectly. Hope this does work well for you in the long run.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 03-15-2019 at 11:39 AM. |
03-15-2019, 11:22 AM | #60 |
Sigh.......
