Old 09-22-2019, 03:50 PM   #1
russcc
Default Purpose/location, E brake Bush 11A-2091
On the '40 I believe there is e brake cable bushing 11A-2091. What is its' purpose and where is it located. See photo. Thank you Fordbarners.
russcc is offline   Reply With Quote
Old 09-22-2019, 07:09 PM   #2
Tony, NY
Default Re: Purpose/location, E brake Bush 11A-2091
It looks like the part # in this drawing. Hard to see. A grommet.
http://www.vanpeltsales.com/FH_web/F...6-48system.jpg
Tony, NY is offline   Reply With Quote
Old 09-22-2019, 07:14 PM   #3
40cpe
40cpe's Avatar
That bushing is listed to fit '41-48.
The '40 uses 91A-2271
40cpe is offline   Reply With Quote
Old 09-23-2019, 05:08 AM   #4
russcc
Thank you Fordbarners. 40Cpe, that's probably why I couldn't figure out how to use it.
Old 09-23-2019, 05:16 AM   #5
russcc
Update. The 91A-2271 is for the e brake wires that go to each rear wheel. Those bushings insulate the wires from the radius rods they are attached to. The one I believe I am looking for is the round one, 91A-2273, that slides over the main cable to insulate it from the X-member where it goes through the center of it. Dennis Carpenter, $4.95.
Old 09-23-2019, 08:43 AM   #6
Kube
Kube's Avatar
There are NO parts with an 11A prefix on a 1940 Ford. NONE.
This particular piece goes on the cable near the "X" member to shield it (cable) from rattling against the frame.
Old 09-23-2019, 04:48 PM   #7
russcc
Thank you Mike. See the later post, 91A-2273. Thank you for confirming it.
Thread Tools
Display Modes
