Old 08-01-2019, 03:02 PM   #1
throwback
Default Nut and bolt gauge for Early Ford
Does anyone know if someone is selling a Nut and bolt gauge for Earl Fords?
Could you provide me with contact information?
Thank You!
throwback is offline   Reply With Quote
Old 08-01-2019, 03:18 PM   #2
Kube
Kube's Avatar
Default Re: Nut and bolt gauge for Early Ford
Thank You!
Do you mean a gauge to tell you exactly what size you have? If so, McMaster-Carr sells gauges in various ranges.
"Imagination is a crutch used by those who lack knowledge and intelligence ."
B
. Franklin
Old 08-01-2019, 03:31 PM   #3
throwback
Looking for a gauge that will tell me the size (diameter), Thread count.
Thank You!
Old 08-01-2019, 04:00 PM   #4
supereal
supereal's Avatar
Ford used a variety of odd sizes and threads, many unavailable except from specialists. For that reason, we never discard bolts or other fasteners. We keep jars and cans full of them, and they come in very handy.
supereal is offline   Reply With Quote
Old 08-01-2019, 04:24 PM   #5
nelsb01
nelsb01's Avatar
I have a Craftsman Tap and Die kit that covers the majority of the sizes. The thread gauge in the kit works for determining thread count and those that you arent sure of, I then use the taps to check.
If you are just looking for a thread gauge, good hardware stores like Ace, True Value and Do It Best still carry them.
As the recently departed Nut and Bolt man said -- you can't restore a vehicle without a thread gauge.
nelsb01 is offline   Reply With Quote
Old 08-01-2019, 04:25 PM   #6
Kube
Kube's Avatar
Thank You!
Check McMaster-Carr. I agree with Supereal that Ford used what we (these days) consider odd sizes. However, Ford rarely used anything (sizes) that isn't readily available even now. Nearly all fasteners were fine thread. Some were coarse thread. I can't think of any that were super fine thread.
You can purchase gauges in both fine and coarse thread sizes.
B
. Franklin
Old 08-01-2019, 06:03 PM   #7
DavidG
DavidG's Avatar
There are some super fine threaded fasteners that were used, but off the top of my head the only ones that I came up with for now are the threads on the '32-'mid-'37 cowl vent handles.
Old 08-01-2019, 06:54 PM   #8
51 MERC-CT
51 MERC-CT's Avatar
One of the 'odd' size screws that Ford used were the #12 size fasteners used primarily to hold window cranks in place and in a few other spots depending on year.
Other than that most of the fasteners are hardware store items.
Old 08-01-2019, 07:25 PM   #9
DavidG
DavidG's Avatar
#12 screws are used extensively on '32s through '34s in both fine and course threads and at the time, #12 was a fairly common fastener size.
Old 08-01-2019, 07:32 PM   #10
Tim Ayers
I have a really useful thread pitch and bolt size in SAE & metric and pipe. I'll snap a picture of it and post it later. I forgot where I got it, but I use it at least once or twice a week.
Tim Ayers is online now   Reply With Quote
Old 08-01-2019, 07:35 PM   #11
Kube
Kube's Avatar
#12's are available through McMaster as well.
B
. Franklin
Old 08-01-2019, 07:59 PM   #12
DavidG
DavidG's Avatar
There aren't a lot of hardware stores who these days carry fine thread fasteners. You have to go fastener specialty houses to get them, as Mike suggests.
Old 08-01-2019, 10:42 PM   #13
fordor41
fordor41's Avatar
Odd is right. I rebuilt the rear quarter windows in my '41 fordor and it had 2 screws that were 8-40 if I remember correctly.
fordor41 is offline   Reply With Quote
Old 08-01-2019, 10:46 PM   #14
Tinker
Tinker's Avatar
If anyone has 38-39 truck used stock bed bolts let me know. I have most, not all. no one makes the bolts.
Old 08-01-2019, 11:30 PM   #15
35fordtn
35fordtn's Avatar
Good luck finding fine thread 5/16, 3/8, or 7/16 carriage bolts they do not exist these days. They were used in mostly In body to frame, and pickup beds to frame. #12 hex bolts are also non existent these days.
35fordtn is offline   Reply With Quote
Old 08-01-2019, 11:47 PM   #16
Tinker
Tinker's Avatar
Ya basically carriage bolts with a y head finish and a square head insert fastener/wrench head. Roy told me, sorry, but no one makes them.
In a pinch you can use regular carriages and engine valve springs from where ever. I prefer the bolts with cotter pins for obvious reasons. They are available but not totally correct.
Old 08-02-2019, 01:45 AM   #17
frnkeore
frnkeore's Avatar
You can get a thread pitch gauge here:
https://www.victornet.com/detail/GA-44A.html
With it, you match the thread pitch, then measure the diameter of the bolt, or screw and you have it.
8 x 40 tap & dies are available, as well as a section of short screws. They are used in gunsmithing work.
Here is a chart that you can compare what you get with the thread gauge ans diameter:
http://www.shender4.com/thread_chart.htm
The first three columns, should get you the answer.
In this period ('32 on) we where on the USS & SAE bolt standard so, most Ford stuff will available, other than "specials" that had to be used for certain things.
SAE, extra fine is still a standard and although hard to find, they are mostly available.
Frank
frnkeore is offline   Reply With Quote
Old 08-02-2019, 04:40 AM   #18
51 MERC-CT
51 MERC-CT's Avatar
Did not have to look any farther than my local Home Depot for what I needed.
Old 08-02-2019, 04:52 AM   #19
36rgtop
36rgtop's Avatar
Just where were #12 hex bolts used by Ford ?
36rgtop is offline   Reply With Quote
Old 08-02-2019, 05:03 AM   #20
oldandtired
A bicycle I am trying to restore for a friend uses 12-24 machine screws and a long 12-24 hex head maybe 5-6 inches long. Maybe if they are unavailable elsewhere a bicycle shop would have them.
oldandtired is offline   Reply With Quote
Thread Tools
Display Modes
