Old 10-04-2013, 02:48 PM   #1
Mike B
Default Carb issue-Ford Model 7rt
It's on this 221 I have...
I'd fired this engine up a few months back with an Electric fuel pump I had...ran fine...
Went to fire it off today and fuel is squirting out of the horn...I pulled the top of the carb off, thinking float was stuck...but noticed only about 1/2 bowl full of fuel, turned the top over closing the float passage, turned key on...no leaks...etc...seat held fine.
Check the fuel pressure on my pump, right at 3.5 Pounds.
Any ideas as to what I need to look for?
Thanks.
Mike B is offline   Reply With Quote
Old 10-04-2013, 03:12 PM   #2
ford3
Default Re: Carb issue-Ford Model 7rt
to much pressure, all that is needed is 2 to 2 1/2 #
ford3 is offline   Reply With Quote
Old 10-04-2013, 03:19 PM   #3
Mike B
Had just been searching the Barn.
Am I correct that the stock pump is built for 3.5 PSI...but pump rod length or gaskets under housing, are to get 2.5 PSI?
Anyways, will try to locate a regulator locally.
Thanks.
Old 10-04-2013, 04:30 PM   #4
billwill
Thanks.
Change presure to 2 lbs
billwill is offline   Reply With Quote
Thread Tools
Display Modes
