Old 10-04-2013, 11:51 AM   #1
oldford2
oldford2's Avatar
Default Holley pressure regulator
Does anyone have a picture of mounting a Holley pressure regulator between the pump and carb using copper lines not hose? Thanks
John
oldford2 is offline   Reply With Quote
Old 10-04-2013, 12:25 PM   #2
Old Henry
Old Henry's Avatar
Default Re: Holley pressure regulator
Here's mine in the frame just after the electric pump but before the mechanical. Still shows how to hook up with metal fittings.
"It is good to have an end to journey toward; but it is the journey that matters, in the end. *Ursula K. Le Guin in The Left Hand of Darkness
Old 10-04-2013, 12:51 PM   #3
oldford2
oldford2's Avatar
Thanks Professor, I plan on keeping my mechanical pump. I have an electric pump down where yours is but seldom turn it on. I will have the pressure gauge on the Holley. Do you use the mechanical pump or just electric. Do you have a gauge somewhere? Thanks
John
Old 10-04-2013, 01:47 PM   #4
Roger/Sacramento
Roger/Sacramento's Avatar
That setup will not regulate the mechanical pump
KIM KARDASHIAN ISN'T FLAT, BUT MY MOTOR IS.....
http://s818.photobucket.com/home/roglehr/index
Roger/Sacramento is offline   Reply With Quote
Old 10-04-2013, 02:24 PM   #5
19Fordy
19Fordy's Avatar
Here's one:
The electric fuel pump near the tank feeds fuel forward to where it enters the bottom port of the Holley regulator. The fuel then exits the regulator to the carburetor as shown on the left hand fitting in the first photo.. A pressure gauge screws into other port on the regulator. With engine running turn Allen screw to adjust pressure and lock the setting with the hex nut..
This regulator has the "low pressure" internal spring and supplies plenty of fuel to a Holley 390 4 barrel.
The lines are 1/4 in. steel (painted black) with "Aeroquip" type fittings that I also painted black after install. Lots of companies make these fittings. Russell comes to mind. Available at speed shops and on-line. Hope this helps.
Click on photo to enlarge.
Old 10-04-2013, 02:29 PM   #6
Old Henry
Old Henry's Avatar
John
I just use the mechanical pump until vapor lock then turn on the electric one. Don't have a gauge plumbed in anywhere.
Old 10-04-2013, 04:08 PM   #7
mike42
mike42's Avatar
OldFord what is your email and I'l send what I did.
Mike42
mike42 is offline   Reply With Quote
Old 10-04-2013, 04:28 PM   #8
oldford2
oldford2's Avatar
Sent you a pm with my email. Don't like to post it because all "those wimmin" will be pestering me.
John
Old 10-04-2013, 11:57 PM   #9
mike42
mike42's Avatar
Photos sent
Thread Tools
Display Modes
