Old 09-29-2013, 11:33 AM   #1
jim1932
jim1932's Avatar
Default screwed up my wiring
I put a new harness in the car and just noticed that my taillight is always on. Whether the switch is on or not. If I rotate the headlight switch the license plate light goes on or off the way is should. What did I do?
Short URL: http://smu.gs/14g7eDW
jim1932 is offline   Reply With Quote
Old 09-29-2013, 11:51 AM   #2
Bob C
Default Re: screwed up my wiring
You sure it's not the stop light that's on?
Bob
Old 09-29-2013, 12:05 PM   #3
PeteVS
PeteVS's Avatar
Bob
It's got to be the stop light. You mention that the license plate light goes on and off per the switch. That bulb is the tail light (the upper of the two bulbs) so the tail light IS working. Is the stop light switch bound up?
Don't never get rid of nuthin!
PeteVS is offline   Reply With Quote
Old 10-01-2013, 07:22 AM   #4
jim1932
jim1932's Avatar
Crap! the stoplight switch moves freely. Something must be grounding it out. That said, does the stoplight work even when the car is switched off?
Old 10-01-2013, 07:26 AM   #5
Rowdy
Yes, Ot wiil work even when the car is off. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 10-01-2013, 07:57 AM   #6
jim1932
jim1932's Avatar
OK must be the switch or the way I wired to the switch.
Old 10-04-2013, 07:33 PM   #7
PeteVS
PeteVS's Avatar
Yep, the stop light should work even when the ignition is off. You should have a test light or voltage meter to see if there's voltage at the terminal to the lights even when the pedal is up. Or, an Ohm meter so you could disconnect one of the switch wires and check for continuity through the switch pedal up and pedal down.
Also, is the spring between the pedal and switch going slack when the pedal is up?
Thread Tools
Display Modes
