Old 06-05-2019, 02:43 PM   #1
mantta
mantta's Avatar
Location: Keweenaw Bay, MI (Michigan's Upper Peninsula)
Default Oil Pump Spring
Have you ever seen an oil pump spring attatched to the oil pan instead of the pump? Seen one today. The spring seemed shorter than the ones I have seen attached to the pump.
mantta is offline   Reply With Quote
Old 06-05-2019, 05:48 PM   #2
Joe K
Joe K's Avatar
Default Re: Oil Pump Spring
That would be yes and I agree with the length.
It seems that Ford experimented with this too. On mine the spring was sort of "rolled" into the bottom drain plug ring. I pulled it out but as with most of these sort of "one assembly" sort of arrangements, the spring wouldn't go back. So I used the little bar notched for the spring as is found on most of these.
Joe K
Shudda kept the horse.
Old 06-05-2019, 06:40 PM   #3
7_Zero
7_Zero's Avatar
Yep, ran into that on my dad’s car just a couple days ago. It has a ‘28 pan with the pan clean out plate so I figured it was a ‘28 thing. What year is the car you saw it on?
7_Zero is offline   Reply With Quote
Old 06-05-2019, 07:19 PM   #4
Joe K
Joe K's Avatar
The engine I saw it on was a 30 model year. No shield on the oil pan tray which came a little later?
Joe K
Old 06-06-2019, 01:43 PM   #5
midgetracer
midgetracer's Avatar
I've found that on 28 engines with the clean out plate and with the later pans.
midgetracer is offline   Reply With Quote
Old 06-06-2019, 02:58 PM   #6
Brian T
Brian T's Avatar
I have that pump spring in my 29 engine, to remove it, it just threads out, to refit thread it back then tap the bottom coil down with a screw driver, makes a click sound when bottomed out.
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
