Old 06-30-2013, 04:32 PM   #1
duffer
duffer's Avatar
Default light switch position
Is my light switch in the correct position? I was told the wires should come out the bottom.Mine seems to be out the top? What do i have to do to fix this? Thanks again
duffer is offline   Reply With Quote
Old 06-30-2013, 05:13 PM   #2
RHD
RHD's Avatar
Default Re: light switch position
Your pic is correct. You will see a small oil drain hole at the bottom of the switch to confirm this. See pic.
R.H.D.
Author of Model 'A' Ford technical manuals.
Supplier of good original RHD parts.
RHD is offline   Reply With Quote
Old 06-30-2013, 07:22 PM   #3
duffer
duffer's Avatar
Thank you vey much RHD,
