01-22-2013, 01:35 PM | #41 |
Re: 31 A Submerged above Intake in Salt Water Thanks to "Sandy"
I wonder how the NYC subways are makingout having the cars and the tunnel filled with salt water?
For the Hurricane of '44, we lived in Brigantine, NJ, on the beach. Mother's 41Ford coupe was in a garage a block off the beach. The garage held but the water inside came up to her floorboards. The owner of the garage had several open cans of used oil sitting around(wartime). The salt water dumped the oil which stayed in the garge and coated the underneath of the car. After the storm, our mechanic cleaned the wheel bearings and we ran the car for another 15 years with no problems. |
01-22-2013, 03:29 PM | #42 | |
01-22-2013, 04:27 PM | #43 |
I think you're overthinking the radiator problem.Yours just got a saltwater bath.Radiators on the road are subjected to a salt spray for thousands of miles at a time.Wet,dry,wet,dry,with lots of time between for corrosion to go to work.They are under a constant barrage of brine in the winter.I think you probably uncovered a problem when you washed it.When you get hard grease piled up around the bottom of the radiator it will keep the leaks sealed up.I have a nice looking original radiator that had a lot of grease on it.I washed it with solvent and a hose,it had 22 leaks after with none before.It was corroded from the inside out,and the grease was holding it all in.I have people see it in the shed and try to buy it from me,it looks like a perfect dimple finned radiator.I really should bash it with a hammer,someday somebody is going to try and sell it as a good radiator.
01-22-2013, 06:58 PM | #44 |
Also instead of using WD 40 try finding a couple cans of Gibbs Brand oil,not the Joe Gibbs racing engine oil but Gibbs Brand it is very usefull in penetrating metal,protecting it cleaning etc,lots of gun owners/hunters use it,check it out and only place I have ever found it is on Ebay,not cheap.
"Never complain,never explain"... Henry Ford II |
